B7 RS4 Throttle Body... Interesting
I can across this post on Reddit.
Interestingly enough, if you’re having an issue with the throttle body and need a replacement, then the Z06’s throttle body will match the RS4’s perfectly. And did I forget to mention at a fraction of the cost? Not sure if anyone had transferred that info over here seeing as the AW post was from 2008, but I thought I’d share.
