badtoyz build thread.
starting a build thread because I have a but load of parts coming and a ton of modifications Im looking at doing. the car is a 2007 phantom black RS4 with 95k miles on it.
as most of you know my current mods are: JHM full exhaust, intake spacers, and 93 tune. ive also just had a carbon clean. and had my trim wrapped gloss back.
this is whats going on my car over the winter.
H&R spings B5 perches.
painted mirrors.
headlights painted and clear corners.
led taillights.
5R clutch with lwfw.
jhm trio.
jhm stage 1.
that’s it for now but as I get into it im sure other things will come up like mounts and so on.
I started with the mirrors toda and as I was searching for info on disassembly I never actually found anything specific to the rs4 but I did come across a thread on rs246 where sar (member here) said he was about to remove a friends mirrors and would do a write up. I then sent him a pm here and he helped me through it and shared this link.
http://forum.rs246.com/viewtopic.php?f=35&t=105561
I got the mirrors off and noticed on my driver side I had some corrosion (apparently quite common) because it was directly under the mirror I never actually noticed it before.
http://i1270.photobucket.com/albums/jj615/Garrett_Hargreaves/Mobile%20Uploads/20141027_005827_zpsra0jqzcx.jpg
because the hole through the triangle piece is not large enough to fit the connectors through u have 2 options to remove the triangle piece.
  1. remove the entire door card and from what ive read is a total pain in the ass and the connector is still really difficult to get to disconnect.
  2. cut the wires and putem back together later.
because im confident in my soldering skills I just cut the wires and popped the triangle off.
I then sanded the corrosion and the entire triangledown with 320 then 400 and then scotch brite. and used some tremclad rust inhibiting flat black and re painted the triangle.
the passenger side was in perfect shape and after painting the drivers side and making sure it matched I decided not to bother re painting it. I know in the one pic of them side by side it looks like don’t match but really they do, its just the way the light bounced off them.
http://i1270.photobucket.com/albums/jj615/Garrett_Hargreaves/Mobile%20Uploads/20141027_011612_zps2p1hhebo.jpg
http://i1270.photobucket.com/albums/jj615/Garrett_Hargreaves/Mobile%20Uploads/20141027_014812_zpsh8ozufgd.jpg
http://i1270.photobucket.com/albums/jj615/Garrett_Hargreaves/Mobile%20Uploads/20141027_014910_zps2nz6cyoe.jpg
good as new! no more corrosion.
I then moved on to the mirrors following the same sanding process. I bought some tremclad hi build fleet coating gloss black to do the mirrors with. Ive never used this before but thought id give it a go. I wanted to paint them in the basement because of temperature but my wife would have none of that. losing that battle I hung them in the garage and put a coat on them. the paint itself looks good but because it was so cold I have a bit of sagging and one run so I now have heaters running in the garage and will san and respray tomorrow.
fyi I planned on 3 coats.
http://i1270.photobucket.com/albums/jj615/Garrett_Hargreaves/Mobile%20Uploads/20141027_041954_zpssi1j0yuw.jpg
http://i1270.photobucket.com/albums/jj615/Garrett_Hargreaves/Mobile%20Uploads/20141027_043718_zpssrfq7hfm.jpg
