Hi all
I was hoping to tap into the combined experience of those on this forum in relation to the recoding of a new Battery into the RS5 (MY15). I have watched Ape’s very excellent video on it (https://www.youtube.com/watch?v=-zDEXfSsk8k) but still looking for some advice about the coding given the battery purchased has numerous numbers on it but no BEM code and the numbers are longer than the VCDS coding instructions refer to. I have attached some photos so you can see the various numbers available on the battery. There is the “Varta Code” number with a QR code also which looks most closely like the BEM code on the OEM battery as well as a traditional bar code but then there are three other strings of code on the battery housing also per the pictures supplied. The issue is each of those 5 separate codes has 12 or more digits in it whereas VCDS says 11 Digits for Battery Part Number, 3 Digits for Battery Vendor and 10 Digits for Battery Serial Number.
My OEM Battery code is 8K0915105F MLA 141015FCC1 (12V 520A 110Ah DIN)
The new battery is 12V 105Ah 950Ah so I am not minded to try just changing one number to trick the car to see a new battery and they have slightly different specs.
The new Battery is a Varta AGM and is the same dimensions exactly to the OEM.
And yes I did contemplate an Antigravity Lithium supplied by RMR but the cost was a little beyond me at this point…yes this new battery is very heavy!
Thanks for any help before I start punching in numbers to VCDS!
