Recently i have been chasing a Fuel Pressure code that has left me stumped. This is what i have showing up:
2 Faults Found:
012555 - Low Pressure Fuel regulation
P310B - 008 - Fuel Pressure Outside Specification - Intermittent
000808 - Knock Sensor 1 (G61)
P0328 - 001 - Signal too High - Intermittent
I am guessing that the Knock Sensor code is being caused by the P310B code. When i searched the code through the Ross-Tech Wiki this is what i came up with:
[i]Possible Causes
Faulty Fuel Pressure Sensor (G410)
Wiring Harness for Fuel Pressure Sensor (G410)
Possible Solutions
Replace Fuel Pressure Sensor (G410)
Repair Damaged Wiring
When found in Audi 2.0T "FSI" Direct Injection engines, may also have DTCs P129F/004767, P2293 and/or P0087. See TSB 24-08-58 (TPI 2017356/2) for more information on testing and updated part numbers.
When found on Direct Injection engines, such as the 2.0T, in combination with system too lean or similar faults indicating a vacuum leak address the cause of those first. Common fault codes are found here
When this fault is stored after all of the typical failure items have been replaced or tested, verify the electric fuel pump and/or FPCM (Fuel Pump Control Module) is operating properly. Low fuel pressure or volume may be the end result of a fuel supply problem including an incorrect fuel filter when the pressure regulator is integral. [/i]
Based on that information I have checked the entire wiring harness for damage. I have checked every single hose for cracks and or a vacuum leak. Checked that the correct Fuel Filter was installed properly and also checked to make sure there was nothing clogging the fuel pickup in the tank. I have tested to ensure the HPFP was working correctly as well.
Digging further into this the Fuel Pressure Sensor (G410) comes back to the electrical sensor on the HPFP. I have verified that the sensor has connectivity and also seems to be functioning properly.
Needless to say I’m pretty stumped at whats going on. The cars ONLY mod is a APR Tune. Ihavent noticed any performance loss and the CEL is NOT on. Looking forward to getting some answers.
