Thanks for clarifying Jbones! I see why my AWE downpipes are really not downpipes now. Although when I ordered them I opted for the non-res for less restriction?
A few months ago Jake actually contacted me about the test pipes seeing if I wanted in on the first batch! We spoke about emissions and that I would likely not pass them once I swapped them in. That is why I didn’t grab them then. I suppose if these are an easy swap without have to drop the engine or trans I could just juggle them when emission time comes around.
They are… and expensive for hollow pipes, but one must pay to play. Also since JHM are first to market they can skim
Most of the time the resonators are just for sound and by sound I mean drone.
The B6/7 S4 downpipes are $1,200 for probably twice as much or more tubing, plus flex joints, and hardware/gasket for the middle connecting flanges. But with the midpipes the B8s are probably paying more in the end.
I’d say they’re pretty well priced. Having the O2 sensor recessed saves you another $50-$100 bucks form buying O2 spacers. And you’ve got madrel bends in 2.5" piping with some fairly complex bends (well more so precise bends since you don’t have flex pipes).
The first DP’s that came to the B6/7 market were twice that if I recall. As time goes on, someone will copy them with slightly less quality and offer for a coup0le hundred bucks less.
But either way, you’ll always be able to sell these for a good chunk back later on if you ever need to.
Also, I’d imagine with proper tune, you’d get around emissions. The visual will never catch these with how recessed the catalytic converter is in stock location. So as long as you’re not throwing a code, you should be good.
Definitely meant drone, resonance inside the car that is like a hum! Even my center light console with the sun glass holder vibrates and shakes. Bluetooth phone calls piss people off so much that certain family refuse to talk while im in my car.
I wouldn’t mind rasp but it only seems to happen when the car is cold, during the first few minutes of drving
If my non-res really has less drone than the res then im glad, because I would have like gone back to stock if the drone would have been even worse!
Very nice post Big. I’ve been thinking more and more about replacing the S4 with an S5. I’d love to see the car in person one of these days. And as we’ve talked about before, it would be fun to do some pulls and see NA vs SC at Utah altitude.
I also have FI exhaust and the JHM stage IV clutch and FW. You could take a drive in my car and see first hand the sound and lack of chatter.
Thanks! Definitely, I would like to do some pulls since the RMR is closed for the winter. Do you have any test results for you current set up? I am still very busy, however, studying for boards and job hunting right now so Im more flexible to meet up. Shoot me a text when you have some time
About ten days ago when I got into my car to start it as I depressed my clutch I heard a quick sharp pop. The car started fine but clutch did not return, and that’s when I immediately thought “OH SHIT! FUCK ME!” Car would not go in gear, although I could easily physically bring the clutch back to no avail it was flopping around like a fish out of water.
I had to get it towed the next morning out of my work’s parking garage. Flat bed truck could not get it, so I grabbed my intern and we pushed it out. It goes to the local shop I have exclusively used for the last 7 years. It sits…I visit the shop the next day and I get the “your car is next after we free up this lift from our race car”. It continues to sit, no phone calls…5 days later I had enough get it towed to another shop that has frequent R8, and supercharged R8s etc…
Within 3 hours they find my brake fluid like tar which has corroded the rubber line between the master and slave cylinder bursting the line. $700 later the car is functional, but the clutch is still hard to depress the final 2 inches of travel (this has been a growing issue for the past 6 months). They bleed the lines some more hoping it is just air. Still difficult to depress.
Turns out there is a fork piece, pilot bearing, and another part that needs to be replaced. I also elected to go stage 3 clutch, which what is in all the supercharged R8s and 600+ ft/lbs of torque cars they do.
The flywheel drops me 4lbs of rotating weight.
Finally I said since its right there lets just slap on some JHM test pipes too. But I just realized the AWE track exhaust + downpipes are narrower than the 2.5" test pipes…I hope this doesnt cause some awkward air flow dynamics and sound…
Wow smaller then 2.5" that sucks. Those jhm pipes should help wake the car up. How big is the awe exhaust. You would have to think they know better then to do the 2.25 thing. Cool update.
Contact JHM or Fast Intentions and see if they will get you a true 2.5 inch exhaust. There is a local guy to me that has a FI exhaust and it sounds great. AWE necks the pipes down to reuse the stock clamps from the end of the downpipes and the beginning of the catback.
Unfortunately, I purchased the AWE exhaust 4 years ago when they were first to the market, so now I will have to upgrade the entire thing once again with the JHM/FI version (if it exists?) I’m having the test pipes put in for now, which should be a nice addition.
The wrap is holding up great! The best part about it is that I have not got any rock chips on the front of my hood. There were a couple larger rocks that have hit the hood and bumper leaving small 1/2 inch tears in the dip but even through high pressure self spray washes those spots haven’t worsened! Still very easy to wash and clean.
The one drawback / negative with the dip is where my wife and I get into the car our feet have rubbed against the side skirts a few times which has caused the area to begin pealing up. I don’t enough dip was applied in this area. I’m contemplating changing up the color and theme of the car again too
I ended up going with the southbend stage 3 endurance clutch $3k. I really wanted to do the JHM clutch and flywheel as that yields an additional 3-6 lbs less than the southbend flywheel. But the shop swears by southbend, running it in all of their supercharged R8 builds, stage 4+ big turbo, and previous S5/RS4s. He assured me that there it is the way I want to go since that’s all southbend does all day is clutches…
I questioned him regarding Arin’s situation when he put the 1740 on his S4 and melted the southbend clutch…he said all clutches are consumable and lifespan depend on the driver. He mentioned the JHM product is excellent but they have seen a few cars come back to be opened up again even though JHM has replaced the parts the car still came back…
I questioned him on what discount he will give me for southbend feeling him out for potential commission that he is getting in return for selling the clutch, but that didn’t get me anywhere.
There is not much left for me to do after this…JHM flywheel, update the exhaust, sell the APR charger for the JHM one when it comes out???
