Body shop Woes
So it’s a long story… here’s the cliff notes version. Unknown neighbor back into my car destroying my front driver side fender then ran luckily a friend saw it all go down and took down the plate #. After some time searching the authorities got me in contact with the driver and they paid for the repairs. I decided since the car’s in the shop just pay extra and have them respray the entire car.
So i dropped off the car early August, i told the body shop i had another car to take their time and get it done right. Two long months later they tell me the car is ready. I pick the car up today and it is immaculate! showroom quality.
i pay the shop and they start telling me my battery died and they put a new one in on them. I didn’t think much of it, actually thought that they did me a favor until i started the car and saw a CEL (there wasn’t one when i dropped off the car) and the car runs like shit. i told them about it and they said put a few miles on it and it’ll go away. so i drove home and the car ran like total garbage CEL started flashing at one point and i only live 10 min away from their shop.
i got home scanned it with my vagcom and literally every category malfunctioned… so i figured maybe it’s the battery let me clear all the codes and see which ones come back. below is what came back and i don’t know if they messed up my motor installed the wrong battery or if there is another issue all together.
Here is the scan any help is greatly appreciated. I plan to take it back tot them in the morning but i’m not sure if that’ll give them a chance to make it worse.
Friday,05,October,2018,20:33:03:59350
VCDS – Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2 (x64) HEX-V2 CB: 0.4436.4
Data version:
www.Ross-Tech.com
VIN: WAUGN74F07N130653 License Plate:
Mileage: 158120km-98251mi Repair Order:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 11 31 15 16 17 19 1E 36 37 42 46
47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUGN74F07N130653 Mileage: 158120km-98251miles
02-Auto Trans – Status: Malfunction 0010
03-ABS Brakes – Status: Malfunction 0010
07-Control Head – Status: OK 0000
0F-Digital Radio – Status: Malfunction 0010
15-Airbags – Status: Malfunction 0010
1E-Media Player 2 – Status: OK 0000
36-Seat Mem. Drvr – Status: Malfunction 0010
55-Headlight Range – Status: Malfunction 0010
56-Radio – Status: OK 0000
61-Battery Regul. – Status: OK 0000
65-Tire Pressure – Status: Malfunction 0010
76-Park Assist – Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F1 910 552 A HW: 4F1 907 552
Component: 5.2L JHM/V1 OCT9 ª0040
Revision: 59H14— Serial number:
Coding: 01050009190F0160
Shop #: WSC 02335 785 00200
VCID: 221EE00888C18C77A81-8076
7 Faults Found:
008530 - Supply Voltage for Fuel Injector Group C
P2152 - 008 - Electrical Malfunction - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101000
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 158120 km
Time Indication: 0
Date: 2018.10.05
Time: 16:04:24
         Freeze Frame:
                RPM: 775 /min
                Load: 47.0 %
                Speed: 0.0 km/h
                Temperature: 99.0°C
                Temperature: 56.0°C
                Absolute Pres.: 1010.0 mbar
                Voltage: 11.811 V
005464 - Throttle Actuator (G186)
P1558 - 002 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 158120 km
Time Indication: 0
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 107.0°C
                Temperature: 51.0°C
                Voltage: 10.160 V
049429 - Second (Slave) Engine Control Module
U0115 - 008 - No Communication - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 108.0°C
                Temperature: 51.0°C
                Voltage: 9.017 V
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: -40.0°C
                Absolute Pres.: 0.0 mbar
                Voltage: 0.000 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 158120 km
Time Indication: 0
Date: 2006.11.23
Time: 12:00:13
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 99.0°C
                Temperature: 56.0°C
                Voltage: 11.684 V
008198 - Intake Manifold Flap; Bank 1
P2006 - 008 - Stuck Closed
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 158120 km
Time Indication: 0
Date: 2006.11.23
Time: 12:00:18
         Freeze Frame:
                RPM: 858 /min
                Load: 14.9 %
                Speed: 0.0 km/h
                Temperature: 99.0°C
                Temperature: 56.0°C
                Voltage: 12.319 V
P1923 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 158124 km
Time Indication: 0
Date: 2006.11.23
Time: 15:54:04
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 60.0°C
                Temperature: 54.0°C
                Voltage: 11.430 V
Readiness: 0110 0101
Part No SW: 4F2 910 156 M HW: 09E 927 156 C
Component: AG6 09E 5,2 FSI USA 0030
Revision: --H01— Serial number: 0102254
Coding: 0000002
Shop #: WSC 02325 785 00200
VCID: 2F38193CCB13311F37F-807A
1 Fault Found:
006246 - Powertrain Data Bus
P1866 - 000 - Missing Messages - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
         Freeze Frame:
                RPM: 0 /min
                RPM: 0 /min
                RPM: 0 /min
                (no units): 30.0
                (no units): 25.0
                Temperature: 83.0°C
                T.B. Angle: 60.0°
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Coding: 0020920
VCID: 313C1F44DD2727EF21B-8064
4 Faults Found:
000 - - - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 24
Reset counter: 72
Mileage: 158114 km
Time Indication: 0
Date: 2018.08.31
Time: 12:40:02
         Freeze Frame:
                Hex Value: 0x00C0
                Hex Value: 0x4282
                Hex Value: 0x0024
                Hex Value: 0x018B
                Hex Value: 0x00FF
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 70
Mileage: 158115 km
Time Indication: 0
Date: 2018.09.07
Time: 17:14:01
         Freeze Frame:
                Hex Value: 0x0000
                Hex Value: 0x6282
                Hex Value: 0x0028
                Hex Value: 0x0183
                Hex Value: 0x00FF
01314 - Engine Control Module
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 3
Reset counter: 72
Mileage: 158115 km
Time Indication: 0
Date: 2018.09.07
Time: 17:14:01
         Freeze Frame:
                Hex Value: 0x0000
                Hex Value: 0x6282
                Hex Value: 0x0025
                Hex Value: 0x0183
                Hex Value: 0x00FF
00493 - ESP-Sensor Unit (G419)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 68
Mileage: 158115 km
Time Indication: 0
Date: 2018.09.30
Time: 14:30:31
         Freeze Frame:
                Hex Value: 0x0000
                Hex Value: 0x5282
                Hex Value: 0x001B
                Hex Value: 0x1063
                Hex Value: 0x06FF
5 Faults Found:
008199 - Intake Manifold Flap; Bank 2
P2007 - 008 - Stuck Closed
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 158120 km
Time Indication: 0
Date: 2018.10.05
Time: 16:04:27
         Freeze Frame:
                RPM: 844 /min
                Load: 14.9 %
                Speed: 0.0 km/h
                Temperature: 99.0°C
                Temperature: 56.0°C
                Voltage: 12.192 V
P0300 - 001 - - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 158120 km
Time Indication: 0
Date: 2018.10.05
Time: 16:04:59
         Freeze Frame:
                RPM: 1858 /min
                Load: 40.0 %
                Speed: 18.0 km/h
                Temperature: 90.0°C
                Temperature: 45.0°C
                Voltage: 12.954 V
000770 - Cylinder 2
P0302 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 158120 km
Time Indication: 0
Date: 2018.10.05
Time: 16:04:59
         Freeze Frame:
                RPM: 1858 /min
                Load: 40.0 %
                Speed: 18.0 km/h
                Temperature: 90.0°C
                Temperature: 45.0°C
                Voltage: 12.954 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Voltage: 0.000 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 158120 km
Time Indication: 0
Date: 2006.11.23
Time: 12:00:13
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 99.0°C
                Temperature: 56.0°C
                Voltage: 11.557 V
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 K HW: 4F0 959 655 D
Component: 7G AIRBAG AUDI8RH30 0400
Revision: 02H30000 Serial number: 003BMD0100Y+
Coding: 0014151
Subsystem 1 - Part No: 4F0 910 339 A
Component: BF-Gewichtsens. H02 0050
Subsystem 2 - Serial number: 6332CSME16751011Q
Subsystem 3 - Serial number: 6342CSME16513B4F8
Subsystem 4 - Serial number: 6352QSME21360D619
Subsystem 5 - Serial number: 6362QSME1E521B39O
Subsystem 6 - Serial number: 63734SME22522473S
Subsystem 7 - Serial number: 63834SME1E562E3BF
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
Shop #: WSC 02334 785 00200
VCID: 619CAF04CD47D76FF1B-8034
2 Faults Found:
01446 - Sensor for Driver Seat; Seatback Adjust (G230)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 32
Mileage: 158124 km
Time Indication: 0
Date: 2016.01.03
Time: 15:53:44
01447 - Sensor for Driver Seat; Height Adjust (G231)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 32
Mileage: 158124 km
Time Indication: 0
Date: 2016.01.03
Time: 15:53:44
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01034820450000
Coding: 4618397
VCID: 2E060438CC1938173C9-807A
2 Faults Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 32
Mileage: 144790 km
Time Indication: 0
Date: 2016.12.16
Time: 18:45:58
01506 - Bulb for Rear Fog; Right (L47)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 28
Reset counter: 29
Mileage: 158114 km
Time Indication: 0
Date: 2018.08.17
Time: 08:03:24
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000016
VCID: 290CF724F5F75F2FE9B-807C
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
5 Faults Found:
02233 - Left Headlight Power Output Stage (J667)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 93
Reset counter: 40
Mileage: 158120 km
Time Indication: 0
Date: 2018.08.07
Time: 10:57:03
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 158120 km
Time Indication: 0
Date: 2018.09.30
Time: 14:31:06
02234 - Right Headlight Power Output Stage (J668)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 158120 km
Time Indication: 0
Date: 2018.09.30
Time: 14:31:09
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 72
Mileage: 158120 km
Time Indication: 0
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 158120 km
Time Indication: 0
Date: 2018.10.05
Time: 16:10:23
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000900042496
Coding: 0062725
1 Fault Found:
02214 - Tire Pressure Warning
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 50
Reset counter: 0
Mileage: 152473 km
Time Indication: 0
Date: 2017.12.10
Time: 10:19:02
         Freeze Frame:
                (no units): 12.0
                Temperature: 1.0°C
                Error Code: 1
                    Not Recogn.
                    Not Recogn.
                    Not Recogn.
                    Not Recogn.
End----(Elapsed Time: 02:12, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
https://www.dropbox.com/s/pavskl0cedna6un/Photo%20Aug%2016%2C%2011%2053%2017%20AM.jpg?dl=0
https://www.dropbox.com/s/xdhmxebkwjo2lxw/Photo%20Oct%2005%2C%205%2011%2014%20PM.jpg?dl=0
https://www.dropbox.com/s/6iagrp0yaqb7l6x/Photo%20Oct%2005%2C%205%2033%2047%20PM.jpg?dl=0
Take it to the dealer and at the very least get the new battery coded in; the ECU needs to know what the battery is so it can manage power saving and such. The interstate battery that was in my car was never coded, so I got all kinds of current dwell errors, misfires, prox sensors not working, etc…
I think a battery from the dealer, plus installation and coding was like $250ish.
Then clear codes and see where you’re at.
Ok thanks for the info, do you know if it’s something i can do if i have a vagcom scanner?
I have to do the airbag recall anyways.
Also how do i post pics?
To post pix either load them to the site or use the
As for the car chances are they had to pull the front end off the car and it looks like either they got wires connected wrong or the entire ecu needs to be reset.
I would re set your ecu and entire system though vag com. Then key up the car and then see what fault codes pop back up.
Thanks I was only able to upload 2 pics to the site not sure why i can’t upload any more.
http://audirevolution.net/addons/albums/images/900874108.jpg
http://audirevolution.net/addons/albums/images/40960193.jpg
i’m currently looking up how to reset the ecu via vag com… not really finding anything definitive but i’ll keep looking.
They likely drained the battery and also might have turned the car on with the front end off.
I did this myself when I was doing the carbon clean and had similar codes.
To reset the ECUs remember you have two of them.
Go into engine module and clear the codes even if you have none. Do that in both ECUs.
You can also do a master clear of all modules but you would have to kinda walk around the program to find that I don’t have that memorized on how to get there.
