So it’s a long story… here’s the cliff notes version. Unknown neighbor back into my car destroying my front driver side fender then ran luckily a friend saw it all go down and took down the plate #. After some time searching the authorities got me in contact with the driver and they paid for the repairs. I decided since the car’s in the shop just pay extra and have them respray the entire car.
So i dropped off the car early August, i told the body shop i had another car to take their time and get it done right. Two long months later they tell me the car is ready. I pick the car up today and it is immaculate! showroom quality.
i pay the shop and they start telling me my battery died and they put a new one in on them. I didn’t think much of it, actually thought that they did me a favor until i started the car and saw a CEL (there wasn’t one when i dropped off the car) and the car runs like shit. i told them about it and they said put a few miles on it and it’ll go away. so i drove home and the car ran like total garbage CEL started flashing at one point and i only live 10 min away from their shop.
i got home scanned it with my vagcom and literally every category malfunctioned… so i figured maybe it’s the battery let me clear all the codes and see which ones come back. below is what came back and i don’t know if they messed up my motor installed the wrong battery or if there is another issue all together.
Here is the scan any help is greatly appreciated. I plan to take it back tot them in the morning but i’m not sure if that’ll give them a chance to make it worse.
Friday,05,October,2018,20:33:03:59350
VCDS – Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2 (x64) HEX-V2 CB: 0.4436.4
Data version:
www.Ross-Tech.com
VIN: WAUGN74F07N130653 License Plate:
Mileage: 158120km-98251mi Repair Order:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 11 31 15 16 17 19 1E 36 37 42 46
47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUGN74F07N130653 Mileage: 158120km-98251miles
02-Auto Trans – Status: Malfunction 0010
03-ABS Brakes – Status: Malfunction 0010
07-Control Head – Status: OK 0000
0F-Digital Radio – Status: Malfunction 0010
15-Airbags – Status: Malfunction 0010
1E-Media Player 2 – Status: OK 0000
36-Seat Mem. Drvr – Status: Malfunction 0010
55-Headlight Range – Status: Malfunction 0010
56-Radio – Status: OK 0000
61-Battery Regul. – Status: OK 0000
65-Tire Pressure – Status: Malfunction 0010
76-Park Assist – Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F1 910 552 A HW: 4F1 907 552
Component: 5.2L JHM/V1 OCT9 ª0040
Revision: 59H14— Serial number:
Coding: 01050009190F0160
Shop #: WSC 02335 785 00200
VCID: 221EE00888C18C77A81-8076
7 Faults Found:
008530 - Supply Voltage for Fuel Injector Group C
P2152 - 008 - Electrical Malfunction - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101000
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 158120 km
Time Indication: 0
Date: 2018.10.05
Time: 16:04:24
Freeze Frame:
RPM: 775 /min
Load: 47.0 %
Speed: 0.0 km/h
Temperature: 99.0°C
Temperature: 56.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 11.811 V
005464 - Throttle Actuator (G186)
P1558 - 002 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 158120 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 107.0°C
Temperature: 51.0°C
Voltage: 10.160 V
049429 - Second (Slave) Engine Control Module
U0115 - 008 - No Communication - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 108.0°C
Temperature: 51.0°C
Voltage: 9.017 V
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 158120 km
Time Indication: 0
Date: 2006.11.23
Time: 12:00:13
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 99.0°C
Temperature: 56.0°C
Voltage: 11.684 V
008198 - Intake Manifold Flap; Bank 1
P2006 - 008 - Stuck Closed
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 158120 km
Time Indication: 0
Date: 2006.11.23
Time: 12:00:18
Freeze Frame:
RPM: 858 /min
Load: 14.9 %
Speed: 0.0 km/h
Temperature: 99.0°C
Temperature: 56.0°C
Voltage: 12.319 V
P1923 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 158124 km
Time Indication: 0
Date: 2006.11.23
Time: 15:54:04
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 60.0°C
Temperature: 54.0°C
Voltage: 11.430 V
Readiness: 0110 0101
Part No SW: 4F2 910 156 M HW: 09E 927 156 C
Component: AG6 09E 5,2 FSI USA 0030
Revision: --H01— Serial number: 0102254
Coding: 0000002
Shop #: WSC 02325 785 00200
VCID: 2F38193CCB13311F37F-807A
1 Fault Found:
006246 - Powertrain Data Bus
P1866 - 000 - Missing Messages - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 83.0°C
T.B. Angle: 60.0°
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Coding: 0020920
VCID: 313C1F44DD2727EF21B-8064
4 Faults Found:
000 - - - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 24
Reset counter: 72
Mileage: 158114 km
Time Indication: 0
Date: 2018.08.31
Time: 12:40:02
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4282
Hex Value: 0x0024
Hex Value: 0x018B
Hex Value: 0x00FF
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 70
Mileage: 158115 km
Time Indication: 0
Date: 2018.09.07
Time: 17:14:01
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x6282
Hex Value: 0x0028
Hex Value: 0x0183
Hex Value: 0x00FF
01314 - Engine Control Module
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 3
Reset counter: 72
Mileage: 158115 km
Time Indication: 0
Date: 2018.09.07
Time: 17:14:01
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x6282
Hex Value: 0x0025
Hex Value: 0x0183
Hex Value: 0x00FF
00493 - ESP-Sensor Unit (G419)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 68
Mileage: 158115 km
Time Indication: 0
Date: 2018.09.30
Time: 14:30:31
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x5282
Hex Value: 0x001B
Hex Value: 0x1063
Hex Value: 0x06FF
