Boost code on 2.0T A5
Any ideas?
Tuesday,31,May,2016,21:00:44:02319
VCDS Version: Release 14.10.0
            Address 01: Engine       Labels: 06H-907-115-CAB.clb
Control Module Part Number: 8K2 907 115 AL HW: 8K2 907 115 D
Component and/or Version: 2.0l R4/4V TF H16 0001
Software Coding: 0114010A190F0160
Work Shop Code: WSC 93009 999 13828
ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001 (AU48)
VCID: 79F3DDAFF8D05DE9285-802C
2 Faults Found:
5671 - Boost Pressure Regulation
P0299 00 [237] - Control Range Not Reached
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 4
Mileage: 176478 km
Date: 2016.05.24
Time: 12:54:09
4201 - Fuel Level too Low
P1250 00 [096] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Readiness: 0000 0000
I just saw this post. That code is telling you that the comanded boost pressure wasnt reached.
The newer 2.0tfsi cars I think have the same issues as the older 2.0t cars where the deverter can go bad. But I also think the newer cars have weaker turbos. Im not an expert on the newer cars so dont quote me on that.
Still from the code the control seems to be an issue. As a bright side this can be more of an issue on super hot days as the air is very thin and it can cause regulation issues. If you can clear the code and get it to come back on in a few days that would lock up that there is deffinitly an issue.
I don’t know if you got my PM Saki but the B8 2.0 TFSI turbos fail more commonly than the older B7 2.0T FSI turbos.
The B8 2.0 TFSI engines came from the factory with the most up to date revision piston style diverter valve that Audi released for the B7 engines. The part number should be 06H145710D.
