C6 S6 - a love(hate) story. (long...)
Hi guys,
We just got back from a 10-day, 2600Km loop through Croatia, touching every bit of the former Yugo Republic. I have to say that the car is awesome to drive on secondary roads through twisty canyons and coastlines. It’s especially wonderful with the windows down and the exhaust roaring as you punch it to pass slower traffic on a 2- or 1.5-lane road. Even with the stiff suspension, after almost 10 years the chassis is still solid and practically rattle-free.
Unfortunately, we had the windows wide open because the AC (Klimat) compressor died on the 2nd day (http://audirevolution.net/forum/index.php?topic=4122.0), in the mountains about Tirana, Albania. It was 39C that day (~100F) and my wife was furious. I had the freon recharged just before we left on her instructions, so it was doubly “I told you so”. We managed to buy a bucket of ice from a fish market in Montenegro for the next leg, but by this time she was entertaining thoughts of buying “the next car” - and that is not something she ever pays attention to. It won’t happen until after Nov when we find out what country we go to the following year (could be right-hand drive…), but unless I can pull a rabbit out of the hat, my time with the 5.2 may be ticking down.
But despite the lack of AC, I was still driving well on the highway and the twisties and sounded great. It would still idle roughly for a short period during warm up, and I still have an unexplained “clunking” sound from the steering/suspension when reversing or parking, but otherwise it was good. Then with about 250Km to go, and after parking in the hot sun for a 3 hour lunch break in Belgrade) the engine started to run rough and I could tell that the misfires were back. At first it was just a rough idle, but while my wife took a shift on the highway she noticed it was running rough at speed. I scanned it with my Carista OBD and saw the following:
Fault codes:
00797 Sunlight Photo Sensor (G107)
00256 Givers for refrigerant pressure / temperature (G395)
P2179 Bank 2, System too Lean off Idle
P2234 Oxygen (Lambda) Sensor B2 S1, Signal Shorted to Heater Circuit
P2005 Intake Manifold Flap; Bank 2, Stuck Open
P0300 Random/Multiple Cylinder Misfire Detected
P0306 Cylinder 6, Misfire Detected
P0309 Cylinder 9, Misfire Detected
P0304 Cylinder 4, Misfire Detected
00474 Control Module for Immobilizer (J334)
02095 Component Protection Active
I’ll get a detailed VAGCOM scan when I see a mechanic.
I don’t know if it was heat-related or not, but I cleared the fault codes and it ran smoother at speed, but still rough at idle. Then after a 30-min stop at the border (at dusk), it ran a lot smoother during the cooler night temps.
Here’s the State of the Union for the 2.5 years and 24K Km I’ve had the car:
A wonky electrical problem which cause the immobilizer to occasionally “immobilize” the car, or perhaps just not start in cold weather, had me replace
  • battery
  • fuel pump
  • passenger door lock (throwing code to trigger immobilizer?)
  • power relays (2x)
  • oil pan sealing flange, valley pan gasket
Persistent random misfire problems, misfires >4000 RPM, along with oil found in the spark plug tubes ultimately lead me to have the engine removed for a major service (http://audirevolution.net/forum/index.php?topic=3652.0)
  • new coil packs for cyl 6,8,9 (first attempt to fix)
  • spark plug tube seals (x2)
  • replace ® or reseal(L) upper valve gaskets
  • Intake Manifold removed, opened, and inner flap mechanism removed
  • oil separator (torn membrane)
  • breather hose (torn)
  • carbon cleaning
  • resolder T14h wiring harness (heat damage to insulation)
  • fuel injector cleaner G001780M3 (2 times)
While the engine was out, these additional items were replaced as normal or preventative maintenance:
  • valve stem seals (x40)
  • front crank seal
  • water pump, thermostat, & drive shaft
  • engine coolant pipe (x2)
  • coolant temp sensor
  • JHM intake spacers
  • oil pressure switch
  • accessory belt & relay roller
After I got the car back, I thought I was home free! For almost 6 months I was driving with no CEL lights (although the cold weather engine no-start occurred, which seemed to be fixed by new power relays) But lately I’ve been getting misfires on cyl 6,9 again, and now 4. I hope new plugs and packs will fix all of these.
Waiting to be installed…
  • plugs & coil packs (x10)
  • A/C Compressor
  • Orifice Tube, for A/C System
  • A/C Receiver/Drier/Accumulator
Additional outstanding/unsolved issues:
  • steering/suspension clunk when parking/reversing, going to have all the suspension bolts tightened. (http://audirevolution.net/forum/index.php?topic=3450.0)
  • AT transmission PARK switch is wonky, sometimes have to push the shifter firmly to P for it to engage. The key is stuck in the ignition and remote door locking is deactivated when this occurs. But during the HOT weather it refused to engage entirely and I had to lock the doors with the key.
  • misfires on cyl 6,9,4
  • Still need to replace the IM, but waiting to hear if there is an upgraded version coming from JHM
So ultimately, it comes down to this:
  1. have I almost replaced everything that is going to break for the next few years and I should stick with the car (If I can convince my wife to forgive…),
  2. what other (reliable?) AWD car should I consider for my next ride? (Preferably 3-6 yrs depreciated…)
