C6 S6 Engine Issues... Help.
Hi all,
First time poster here, but long time reader. About a year ago I bought a 2007 S6 one owner car with 37k miles (with a 5 yr / 50k JDMA/Fidelity Platinum Warranty). I immediately did a service and had it inspected (high level) and since then I’ve put about 3500 miles on it. A couple of months ago I had a check engine light come on and the anxiety started. The initial diagnosis was that there was an intake flap/manifold issue (the flap was stuck). While the car was in the shop I had the oil changed, air filters replaced, spark plugs replaced, and while the manifold was off I went ahead and had a carbon cleaning done as well. It wasn’t terrible, but knowing what can happen I did it pro-actively. I get the car back, carbon cleaned, new manifold and new check engine light… Every time one thing is fixed/changed, the light comes back… It’s now been about 6 weeks and below is a list of what’s been done (and shop notes/invoices are attached).
Entire manifold replaced
Checked for vacuum leaks and replaced a hose with a very slight crack
Carbon Cleaned (walnut blasted)
New spark plugs
New Coil Packs on cyl 5-10
New PCV (Crankcase Valve)
New Fuel Injectors on cyl 5-10
The misfire’s have come on cylinders 5-10, not sure about the latest yet since it happened on Saturday and the “engine specialist” at the dealer who’s been working on my car was out. The injectors were the last thing replaced. About 10-15 minutes after picking up the car under moderate acceleration (about 4000 RPM) I felt a little stutter/misfire, and the Engine Light started flashing again. Upon easing off the accelerator the light went off. I turned around and headed back to the dealership. I again tried a heavy acceleration run, light started flashing and back it goes to the dealership. So far the warranty company is in for about 8-10k, but more importantly, I’ve been dealing with this for about 6 weeks. Anyone any good pointers here? I know I’m not the first with these issues, but I also feel like we’ve hit the most common problems and I fear there’s no end in sight. Any help/insight is much appreciated…
End rant.
