Update 7/27/2016
Now that JHM has had a chance to look over the whole car, we’ve come up with a game plan. Here are their findings, and the work we’re planning to do:
Front/Rear brakes
Mine are shot (grooved & warped), so JHM is installing their lightweight rotor kits on all 4 corners, which will reduce the rolling weight by ~31lbs in front and ~10lbs in the back. This is an item that I was hesitant about for a while, concerned that the money could be better spent on a different upgrade/repair, but JHM is confident that this is a huge upgrade and shouldn’t be skipped, so we’re moving forward with it. New Hawk HPS pads will also be installed.
Transmission
I’ve never been real happy with the feel of my transmission, it just feels a little slippery/slow and also has the infamous ZF lurch while in sport mode. JHM didn’t find anything specifically wrong as far as I know, but they’ll be doing a fluid flush to see if that helps. I’m not sure if a TCU tune has been developed yet, I keep forgetting to ask.
Fluid & Vac leaks
There were no major fluid leaks, but as would be expected on a 120k-mile car, there are a few minor ones to be addressed. Crankshaft seal, water pump, upper radiator hose, oil pan seal, coolant reservoir, valve cover gaskets, and vent hoses (oil separator to valve cover & crank case to MAF hose) are all being replaced. The vent hoses were a major contributing factor for the lean mixture codes and rough cold idle. Later in the project, it was also discovered that the oil cooler was leaking, so this needed to be replaced as well.
Suspension
My front suspension is toast, which I already knew. They are rebuilding it with a Meyle control arm/tie rod kit, then doing an alignment.
Engine
Coil packs are dated 2009, so they are being replaced. The fuel injectors tested fine, so I think we’ve decided to leave those alone for the time being. The spark plugs were soaked in oil from the bad valve cover gaskets, and probably needed to be replaced anyways, so they’re putting in NGK Laser Platinum plugs. Replacing the fuel filter. My accessory belt was shreddded, so they’re replacing that and installing a JHM belt tensioner. Also a JHM lightweight crank pulley. Performing a carbon cleaning, installing the JHM 8mm intake spacers, and flashing the ECU with a JHM beta tune. Near the end of the project, 2 engine mount were found to be in bad shape. One was completely broken/separated, the other leaking fluid. Being a less-critical and quite expensive item, I opted to replace just the severely broken one for the time being.
Various
Some of the rain trays and such were either broken or missing, so they’re installing new ones to protect everything, especially the ECUs.
It’s a lot of work, but I’m happy to be taking care of it all at once. The car is definitely in good hands, JHM has been spectacular to work with and I can tell they’re excited to start digging into this project! As I mentioned before, I’m letting them use the car for R&D to develop some new ideas for these cars, so it’ll be interesting to see where this leads. I’m also very excited to see the difference in my car, I’m guessing it will be like night and day. Should be a great example of what these cars are capable of with good maintenance and proper upgrades!
