C6 S6 misfire
One if the members (V8A6) recommended in post here as opposed to audizine, so here I am!
I’ve searched to no avail on this issue; as far as I can tell, no one else is experiencing it/has experienced it.
Related or unrelated data:
  • 5.2L V10, muffler delete, no other mods, 2008 Audi S6 (pre-facelift), 76,000 miles
  • I just had the carbon cleaning done on the intake valves. The car was misfiring at 3-4k RPM’s consistently on one cylinder. Replaced the injector on that cylinder and all was fine.
  • The car, when below half tank of gas, acts noticeably different, especially during warmup (a lot rougher the lower the tank is). I don’t think this is my imagination.
  • Fuel gauge seems to be off but hard to say for sure. When I fill the car up, it stays “full” for quite a few miles. As the tank depletes, it eventually starts to line up with where I think it should be. Could just be an Audi thing (first Audi I’ve owned), or my imagination, or mean nothing at all.
  • My ABS module needs to be replaced (ABS/ESP/TCS lights are on, parking brake malfunction… the works. Audi says I need a new ABS module and the internet seems to agree)
  • A year or so ago, the engine threw a code for low fuel rail pressure that never came back, and only once.
  • The car will have a very light “smoke” coming from the driver side of the engine bay occasionally. This ONLY happens when driven hard, generally when corners are involved. I drove from Seattle to Portland (200+ miles) and the smoke didn’t appear, but it does after hitting a corner quick, but not always. The smell smells like a burnt rubber but I can’t tell. The tires look fine.
Take this info with a grain of salt. I’m a computer science guy, not a car guy. I have more knowledge than your average guy but not near enough.
The problem:
ECU has thrown two misfires for P0300 (random cylinders) as well as 7, 8, and twice on 10. I’ve revved it high and hard in a straight line, even after clearing the codes, with no problems. These codes, however, were all thrown while accelerating hard around a corner from a stop. Am I just being an idiot doing this? Or is there something I need to address? I’m guessing fuel system but can’t be sure. Also thought it could be motor mounts. Again, not sure. The engine doesn’t give too much of a rumble but you can definitely feel it in the cockpit. Of course, it is a V10, so I figure this is normal.
The car had an odd idle feeling this morning after clearing the codes. It would get very quite and then bounce back to normal volume. The RPM’s would range from 630~680 at idle while warming up. The problem seemed to dissipate after the car was warm and had been driven a few miles.
Also wouldn’t mind recommendations on the ABS module. Would like to get away with getting it done RIGHT but not spending $2300. I will do so if necessary though.
Thank you all!
Nate
