Have to swap engines in my C6 S6. Curious if I need to reprogram my ECU’s to the new engine, for immobo?
Any assistance / guidance would be greatly appreciated.
You do not. If it’s just the motor there’s no need. Just unplug the wire harness from one motor and drop in the other. It’s once you move dash / ECU or Key assembly you’d need immo support. Or if you were putting a non V10 motor in the car you’d need that support.
Thanks so much CountVohn!
