Carbon Clean / Valves / Turning motor - C6 S6
Hi All,
Took my intake manifold off today in order to do a carbon cleaning.
Definitely needs it - on top of this, the carbon has caused my manifold flaps to also fail.
Anyways, I have been watching some videos and reading up on the process, and I decided to try the method where you fill the intake runners with carbon cleaning solution and let it soak, then vac it out or soak it up with a sponge, which should allow you to then easily wipe away what’s left.
I bought a can of LiquiMoly Petrol Engine Intake Decarb
http://www.liqui-moly.com.au/products/petrol-engine-intake-decarb-2733/
Now, obviously before you can fill the intake runners, you must make sure the valves are completely shut, lest you fill up your cylinders and flood the engine - or worse, cause the engine to hydrolock (is that even possible with this type of fluid?)
Because the valves are so carboned up, it is hard to see/be 100% sure the valves are closed.
Is there a way to tell based on one cylinder’s valve position which other cylinders will be 100% closed?
Further, obviously at any angle of the engine, some valves will be open. How do you manually turn the engine over to operate the valves? Normally I would do this with the crank nut, but this car doesn’t have a crank nut!
Has anyone done this before?
Am I going about this the wrong way and making life difficult for myself?
Thanks for any help/replies!
Cheers,
P
