Cat Replacement Options for B8 RS5
Hey everyone, names Steve, long time follower of the rs5 forums. This is my first time starting a new topic, so hopefully not screwing anything up!
Long story short, there are telltale signs the cats are going bad in my 2015 RS5 with only 55k miles on it. I have JHM downpipes and rest of exhaust is stock. Bad news is I am just outside the 8 year emissions warranty, so SOL there.
I am just looking for any alternatives anyone has seen for replacing the cats. I have looked into JHM and am considering their de-cat racing headers, but truthfully do not want to run catless. Aside from OEM, has anyone seen any other solutions? Especially interested in high flow options if available.
I did see in other forums that there was discussion on going with JHM racing headers and running downstream cats, but never saw any posts on anyone actually doing it. Does anyone have any insight on this / has done this to their car already?
Thanks everyone!
I know an rs5 owner named Steve. Any chance you’re from Atlanta?
Anyways hit up JHM as they make headers and if you’re lucky they’ll maybe sell you a stock cat replacement.
55k is about right for RS5 Cats. Anyone else running their RS5 with more miles than that has damaged Cats whether they know it or not. An inspection from the S1 sensor bung with a video inspection camera will be the best way to inspect for damage. As for what to do if you want to keep Cats, depending on where you live and what you have for good shops around?? A downstream Cat is best for both the RS5 (stock or modded) and even the 3.0t (last ok if you’re stock, but not Stg 1 or 2). For OEM Audi put the Cats as close to the engine to speed warmup which helps in the EPA startup emissions cycle, but that extra heat that helps the warmup cycle damages the Cats. I’m going to go with a Downstream Cat on my S5 but I think I’m leaving my RS5 Catless, the Motronic does a pretty good job of keeping the raw fuel smell low on the RS5 compared to my older C5 RS6 that’s Catless.
Interesting topic, and with about 90k KM on my car, or about 55k miles, it looks like I better pay attention to this topic! As we say here… “subscribed”… I already had a very light “tinkling” sound from the left side cat area and my mechanic said “yeah, you are right there is likely something loose in there but just ignore it for now”. I guess I have some work to plan for in the next year or so!
If you’re lucky it’ll break up into smaller chunks and end up in the Resonator, Muffler, or completely blow out the back. Evenutually anything in the Resonator or Muffler will probably rattle around and erorde enough to go out the back. Unlucky and large chunks will break and block the flow, causing high EGT’s, driveability issues, an O2 code and more.
No, but I did almost buy my RS5 from Atlanta! Flew there from Chicago, car was falsely advertised as being “pristine” and looked great in pictures, but got there and it was a POS. Paint looked like it had hardly any clear coat on it and they tried to pull the whole “it’s just dirty, we will wash it while you are signing papers” trick. I swore I would never try to buy a car from Atlanta again, live and learn!
Anyways back on topic. I did reach out to JHM and they only offer cat deletes ATM, so no luck there. I also reached out to Magnaflow since they have something “in development” but have no ETA, so I don’t have my hopes up there.
Also good to know downstream cats are feasible, just didn’t know if anyone on here has done it yet. I will reach out to a few exhaust shops and get some pricing / options to see what this will look like.
Mine started as a somewhat metallic rattle sound on the right side towards the back of my car, which leads me to believe it’s chunks of the cat. Only hear it under certain rpms and went through the exhaust to make sure everything was tight. I initially thought it was the exhaust valves, but after reading here I’m guessing it was the cat breaking down!
Does anyone have recommendations for high flow cats they have used before?
I’m surprised to hear that about JHM. I know when they first started modifying the Headers to Catless they were originally planning to offer high flow Cats as an option.
