I recently installed a JHM intake manifold and after about 150 miles the CEL came on. I scanned it with my shop’s generic scan tool and got a P1602/005634 - Power Supply B+ Terminal 30: Voltage too Low and P1128/004392 - Fuel Trim; Bank 1 (Mult): System too Lean - Intermittent. I figured it might have been from having the battery disconnected so I cleared it. 150 miles later the P1128 is back. Now it looks like there actually might be a problem so looked I into it with VCDS and here’s what I got.
Address 01: Engine Labels: 079-910-560-BBK.lbl
Control Module Part Number: 8E2 910 560 C HW: 8E2 907 560
Component and/or Version: 4.7L LC/93+JHM G 0010
Software Coding: 0007711
Work Shop Code: WSC 06325 000 00000
VCID: 275706F2964ABF2040F
1 Fault Found:
P1128 - 001 - System too Lean - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 126854 km
Time Indication: 0
Freeze Frame:
RPM: 1854 /min
Load: 9.4 %
Speed: 48.0 km/h
Temperature: 60.0°C
Temperature: 0.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.716 V
Readiness: 0000 0101
I did a little research and it looks like I should try re-seating the intake and re-torquing the bolts. Has anyone else run into this and if so what was your fix?
