Hello guys. About a week ago I got a CEL. Upon scanning I found the 16405 and 16395 codes.(plus a few other codes) Right about the same time the codes came up, a loud clacking sound started coming from the area of the intake manifold. The sound seems to come right from the middle of the IM.
Scanning again today I found the 17755 and 17748 codes.(plus a few new codes)
Can a bad IM cause these codes?(bad/broken intake flapper,maybe?) Something is clacking around in there pretty loudly.
Also, maybe this could be related,the paint on the runners on the passenger side of the IM is peeling off. Probably from overheating? Judging from the other CEL codes I’m getting, the engine seems to be running lean and is knocking.
I’m hoping I don’t have to pull the engine to replace bad cam adjusters. Could I get lucky and replace my IM with a nice shiny new IM from JHM and have these codes go away? (I’m guessing probably not)
Here are my last two VAG-Com scans.
[b]Saturday, 9 August 2014, 16:30:26:58502
VCDS-Lite Version: Release 1.1
Control Module Part Number: 8E0 910 560 C
Component and/or Version: 4.7L V8/5+ JHM.SG 0010
Software Coding: 0007771
Work Shop Code: WSC 08252
VCID: 253D9611ACEF
6 Faults Found:
18530 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 2: Too Lean
P2098 - 002 - Lower Limit Exceeded
18528 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1: Too Lean
P2096 - 002 - Lower Limit Exceeded
16405 - Bank 2: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
P0021 - 008 - Implausible Signal
16395 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
P0011 - 008 - Implausible Signal
17730 - Knock Sensor 3 (G198): Signal too Large
P1322 - 001 - Upper Limit Exceeded - Intermittent
17732 - Knock Sensor 2 (G199): Signal too Large
P1324 - 001 - Upper Limit Exceeded - Intermittent
Saturday, 16 August 2014, 15:29:12:58502
VCID: 253D9611ACEF
9 Faults Found:
17755 - Camshaft Position Sensor 2 (G163) / Engine Speed Sensor (G28): Incor. Correl.
P1347 - 001 - Upper Limit Exceeded
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
P1340 - 001 - Upper Limit Exceeded
16717 - Knock Sensor 2 (G66): Signal too High
P0333 - 001 - Upper Limit Exceeded - Intermittent
16712 - Knock Sensor 1 (G61): Signal too High
P0328 - 001 - Upper Limit Exceeded - Intermittent
17738 - Knock-Control: Cylinder 6: Regulation Limit Exceeded
P1330 - 001 - Upper Limit Exceeded - Intermittent
17739 - Knock-Control: Cylinder 7: Regulation Limit Exceeded
P1331 - 001 - Upper Limit Exceeded - Intermittent
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
P0106 - 008 - Implausible Signal - Intermittent[/b]
