After a LOT of recent work and the car running just great, I found the Check Engine Light come on. Any help diagnosing much appreciated. Thanks all.
Here’s the VAG COM error codes with faults:-
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F1 910 552 A HW: 4F1 907 552
Component: 5.2L V10/4V FSI ª0040
Revision: 59H09— Serial number:
Coding: 01050009190F0160
Shop #: WSC 22164 444 72964
VCID: 224B9771FD637B56A7-8076
1 Fault Found:
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 218371 km
Time Indication: 0
Date: 2018.01.01
Time: 17:05:59
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 3.0°C
Temperature: 5.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 11.557 V
Readiness: 0000 0000
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0210
Revision: 27120501 Serial number: 10601000498013
Coding: 0000007
Shop #: WSC 23890 444 11078
VCID: 63C5D275A2F9325EEC-8036
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
1 Fault Found:
00191 - Passenger’s Door Handle Touch Sensor (G416)
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 250
Mileage: 218013 km
Time Indication: 0
Date: 2017.11.09
Time: 14:37:59
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 731 P HW: 4E0 035 729 A
Component: Interfacebox H43 2750
Revision: 00000000 Serial number: 393GW067500188
Coding: 0010003
Shop #: WSC 02335 785 00200
VCID: 2F6D6E45BEB1C63E38-807A
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H02 0060
Subsystem 2 - Serial number: 00000000482786
Subsystem 3 - Serial number: 0126.07.060000000100010164ÿ
Subsystem 4 - Serial number: 010164ÿ
3 Faults Found:
02873 - Control Module for Back-Up Camera (J772)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 35
Mileage: 217994 km
Time Indication: 0
Date: 2017.11.09
Time: 13:10:12
01327 - Control Module for Parking Aid (J446)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 35
Mileage: 217994 km
Time Indication: 0
Date: 2017.11.09
Time: 13:10:45
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 35
Mileage: 218010 km
Time Indication: 0
Date: 2017.11.09
Time: 13:35:21
Freeze Frame:
Bin. Bits: 01
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F1 820 043 AC
Component: KLIMABETAETIGUNGH20 0170
Revision: 00000030 Serial number: 00000000291773
Coding: 0524330
Shop #: WSC 02325 785 00200
VCID: 5BB5EA959A890A9EA4-800E
1 Fault Found:
00797 - Sunlight Photo Sensor (G107)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 29
Reset counter: 15
Mileage: 218045 km
Time Indication: 0
Date: 2017.11.19
Time: 08:01:14
1 Fault Found:
012953 - Catalyst System; Bank 4
P3299 - 002 - Efficiency Below Threshold - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 218043 km
Time Indication: 0
Date: 2017.11.17
Time: 13:49:36
Freeze Frame:
RPM: 1675 /min
Load: 22.7 %
Speed: 60.0 km/h
Temperature: 93.0°C
Temperature: 18.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.478 V
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
Shop #: WSC 02334 785 00200
VCID: 61C9D87DB8E5204EFE-8034
3 Faults Found:
01446 - Sensor for Driver Seat; Seatback Adjust (G230)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 15
Mileage: 217992 km
Time Indication: 0
Date: 2017.11.09
Time: 13:10:10
00003 - Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 15
Mileage: 217992 km
Time Indication: 0
Date: 2017.11.09
Time: 13:10:10
01445 - Sensor for Driver Seat Fore/Aft (G227)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 15
Mileage: 217992 km
Time Indication: 0
Date: 2017.11.09
Time: 13:10:10
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01016900270000
Coding: 4618269
VCID: 2E537341B9BBCF3633-807A
1 Fault Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 15
Mileage: 213799 km
Time Indication: 0
Date: 2006.04.14
Time: 00:27:57
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000700026853
Coding: 0062725
1 Fault Found:
01521 - Sensor for Tire Pressure
002 - Lower Limit Exceeded - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 3
Fault Frequency: 49
Reset counter: 54
Mileage: 214270 km
Time Indication: 0
Date: 2016.08.21
Time: 16:24:37
Freeze Frame:
(no units): 69.0
Voltage: 14.00 V
(no units): 19.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
