Chemical carbon cleaning
I know this has been covered all over the web but i thought i would share some personal real world experience with regards to chemical carbon cleaning.
I witnessed a B7 RS4 undergo 3 treatments of this solution by BG products - https://vimeo.com/3989681
Once the treatments were completed the manifold was removed after a 1000 miles or so and the results were really quite noticeable and impressive however there was a really big issue.
The cleaning fluid took the path of least resistance through the manifold and only one of the inlets was clean and the rest were pretty much untouched. The conclusion was that if the fluid could be diverted into each inlet port the results would be really rather good.
My immediate thought was could something like a nitrous oxide jet be installed over each port and be fitted with a blanking plate so that they become a permanent fixture for preventative maintenance use?
We seem to have some pretty clever guys here so thought i would put the idea out there.
