I found some water pooling in the front passenger footwell after the car sat in a very heavy rain and I realized that the front sunroof drains on both sides are clogged.
I pushed a length of cable wire down from the sunroof drain inlet and also up from the outlet at the front door––there seems to be a blockage near the base of the A-pillar. I can see some mud on the cable ends when I poke from the bottom.
Is there a trick to clearing this? I don’t think compressed air will be enough.
Is there a kink in the drain at the base of the A-pillar or is this just a blockage that needs to be cleared?
