I’ve been trying to get to the root cause of some cold start misfires I’ve been having, and I think it’s the injectors.
On cold starts, the car consistently misfires on cylinders 4 and 7 while idling. I have tried moving the coils and plugs around, but the misfires do not move, leading me to believe it could be the injectors. I do get misfires occasionally on the others at higher rpms (something else I need to troubleshoot eventually), but on cold starts it’s constantly 4 and 7.
Do you guys recommend changing out all the injectors while I’m in there? or just the problematic ones?
I was looking over injector prices and they seem to vary quite a bit. I can pick them up locally for 178 CAD at the dealership. But then I found them on a few sites for cheaper…
Mfg is CTS turbo but they’re described as “OEM”? They’re 87.50 USD each (!)
http://www.ctsturbo.com/cart/products/RS4_Fuel_Injector_Set_of_4-346-111.html
Some OES ones for 99.95 USD each
http://www.ecstuning.com/Audi-B7_RS4--V8/Search/SiteSearch/Fuel_Injector/ES2081134/
Which ones would you guys recommend? Also, are doing the seals (part 06E-998-907) recommended too? They’re $11 CAD each at the dealership.
EDIT: just to add, the plugs are somewhat recent - about 1.5 years and I think 15-20k kms. Fuel filter was also changed pretty recently. Coils were never changed but are the non problematic revision.
