Comparing APR Stage 3 to JHM Supercharger Kit on the B7 RS4...
So since these Supercharged cars started to hit the track I’ve pretty much made my decision that I will be searching for a very clean low mileage RS4 to purchase in the next year or so… IMO the AMD kit is something I would never buy and the TTS Kit is made overseas and I personally wouldn’t strap on a 10k+ blower from a company in another country on my daily driver expensive Audi.
Leaving two good viable options, APR and JHM. There has been a lot of discussion and multiple threads about this but I’d like to break down both kits pro’s and con’s and also every modification done to each car. I will only discuss the full weight, pump gas runs as I feel they are the most ‘realistic runs’.
Based off of the results and pricing which one would you chose? Both companies are very well proven and have shown to be reliable over the years so I think either way you can’t go wrong. One thing that I don’t like is how APR will not release a solid number on boost, whereas to my knowledge the JHM kit runs ~8psi…
APR’s run:
DA was -58
Modifications:
APR Stage 3 Supercharger Kit
APR High Pressure Fuel Pump Upgrade
JHM Stage 5R Clutch and Flyhweel Kit
Magnaflow HFC’s in stock diameter
19" TSW Wheels (46lbs) on street tires
K&N Drop in filter
93 Pump Fuel and Full weight
Best run:
60’ was 1.654
1/8 ET was 7.2
1/8 MPH was 99.02
1/4 ET was 11.156
1/4 MPH was 123.11
It seems the APR car has a no lift shift program and also launch control.
JHM’s run:
DA was ~+200
Modifications:
JHM Supercharger
JHM Stage 5R Clutch and Flywheel Kit
JHM LW Crank Pulley
JHM LW F+R Rotors
18" Wheels (~46lbs) on street tires
JHM 2.75" Catless Downpipes with 2.75" Catback
JHM Intake Spacers
91 octane and Full weight
Best run:
60’ was 1.697
1/8 ET was 7.215
1/8 MPH was 100.131
1/4 ET was 11.12
1/4 MPH was 125.755
So given all the information above it seems like the two kits are giving very similar results, the JHM car is slightly more modified however the APR car has upgraded fuel pumps and also is probably running a little more boost. I’m guessing probably somewhere between 12-14psi on 93…
Do you guys think the motor will be okay in the long term at those boost levels?
I’m a fan of both JHM and APR, however given the information above I think I would opt for the JHM kit over the APR for a few reasons… Those reasons being it’s probably cheaper, it’s faster and quicker on stock fueling and 91 octane, and at lower boost levels it’s probably safer for the motor in the long term…
I do love how both companies are doing testing on the track rather than a Dyno and I think that with the same supporting mods on both cars, and both on 93 in good conditions they can both go 10.9X and 125+MPH…
Sorry if some of this is repeated stuff from other threads but I thought it would be cool to look at both runs next to esch other and seeing how close they really are, rather than all the information being scattered…
If their are any errors in the modlists feel free to correct me guys…
JHM Slip:
http://i1219.photobucket.com/albums/dd440/Auditude20T/f36a30e1ef9cd45e7754ea702946502b_zps7676553a.jpg
APR Slip:
http://i1219.photobucket.com/albums/dd440/Auditude20T/8cf2dadd26f2253ccaa8bc56f6fcc8f4_zps23596834.jpg
