So we logged Mistro’s car the other day, and logged mine the same day. One of the parameters we logged was engine torque, so I thought I would post up the plot.
FIRST OFF: The VAGCOM torque metric is not a dyno. It’s not crank torque. It’s just a parameter that the ECU calculates. So you can’t compare it to dynos. You can’t compare it to crank hp. The measure the ECU puts out is torque measured in newton metres. I converted it to ftlbs and then extrapolated the HP using the standard tq x RPM / 5252
We are looking for delta here…that’s it.
So here are the two cars
Sakimano - 08 RS4 bone stockwith no passenger and 1/2 tank of gas, never carbon cleaned
Mistro - 08 RS4, JHM 93 tuned, JHM Stage IV clutch+LW flywheel, JHM LWCP piggies, JHM intake spacers, ECS Hpipe, ONE passenger (ME 245 lbs), 1/8 tank of gas, carbon cleaned 10,000 miles ago
So the Mistro car has a weight disadvantage of about 200 lbs
[b]Sakimano - 304 tq @ 5680 RPM…378 hp @ 7760 RPM
Mistro - 340 tq @ 5400 RPM…446 hp @ 7760 RPM[/b]
Most interesting how much stronger his car is up top. Carbon for me I guess along with the piggies and the tune for him. He is 12% up on me in torque, however he is 18% up on me in peak hp…
http://i375.photobucket.com/albums/oo193/sakimano/mydy_zps27a9ca70.jpg
http://i375.photobucket.com/albums/oo193/sakimano/Mistro_zpsb838997f.jpg
