good idea… one misconception I see is that compression ratio of the motor is directly related to the cylinder pressure you see in the test. While it is, you also have to consider the cams and how much overlap is allowed.
See the stock 2.7T numbers the count posted, the pressures are higher than you’d normally see with a 4.2 despite the 4.2 having an 11.0:1 scr and the 2.7T having a 9.3:1 scr. The 2.7T cams have less overlap and therefore let less air escape before the valves seal up.
You beat me too it. Great post beem. This is why I was just going to start a 4.2 S4 thread. This way each member will be able to see a reference to there motor. I was going to do the same for each of the populated boards on the site.
a cool idea would be a communal compression test kit, we could get lots of data if we had a test kit we could ship around instead of havin people pay for their own kits/getting the test done. I’d be interested to see rpm/sec vs compression numbers for similarly modded cars.
