Couple things I was thinking about today. Are you familiar with the exhaust system on the 3.0? I know this is obviously a restriction, and a hinderance with it is that apparently you either have to drop the subframe or lift the engine just to get to the downpipes.
I’m assuming that the simplest form of the tune will need to be accompanied by removing the precats, like the “piggies” that are done with the b6 s4’s… This could prove to be difficult in that case, not sure if that’s true as I haven’t seen it myself.
Next, with the theoretical power gains that will be had from this work, will the stock brakes need to be upgraded? My guess would be no, I compared sizes to a few other vehicles and they were the same or bigger than most cars under 300hp, but I figured I’d ask.
Last is regarding the TIP tranny. I’m guessing outside of forced induction it should be more than capable of holding up to the increased power. You and Keaton touched on improved shifting for it. I know that even in tip shift mode it seems to be delayed, which is rather annoying… is that a limitation of the hardware or software? . While S and tip are definitely way more sporty than D, they are very sluggish compared to the 6 speed… I know a couple companies rebuild the tranny components and apparently that greatly improves the shifting and durability, but my guess is that a lot of that sluggishness is just due to programming. My pipe dream for the transmission would be to have it drive nice and smoothly with increased response in D, but when you switch to S or tip it goes into beast mode with nearly instantaneous shifts. I’m not sure how the s4 was programmed, but I thought I read about it being improved on them. With the S4 was this all done through the ECU? Or did they need the TCU recoded… I guess justincredible could comment on that.
