Here in Texas right now we’re dealing with very cold temperatures of around the 20s, and so everything is being affected. Seeing as my car sits outside, it’s frozen to a decent degree and after finally thawing open my driver’s door decided to turn the car on. After turning it on, the check coolant message appeared prompting me to open the hood and check the coolant levels.
It looked significantly lower than the minimum. Is this typical for the coolant to contract that much to where it would trigger the check coolant levels? There’s no sign of a leak, but I’m just curious and somewhat concerned.
How easy is a DIY coolant change? Is it safe to simply add more coolant mix in?
     Greg5OH:
 Greg5OH:
