On mine, the fan ran, but it wouldn’t shut off. The solution was to replace the motors.
Yeah I’m trying to avoid that if possible since they’re so damn expensive
Yes I agree
Hard to find in Canada and very expensive, I will keep you updated and send a pic or two of my switch set up as long as it works!
Cheers
Do you know if you can replace at ac pressure sensor without having all the coolant escape? I bought a new one from Audi. I found a video on an A6, I guess those ones have a valve on them that closes as soon as you remove the sensor, but I’m not sure if the s6 has that same system.
Yes you can, there is inside smal valve like on tire, just Unscrew sensor switch, you will hear small psst and thats all. If you get long pssssssssssssssst thats mean vlave is fault.
I replaced my couple months ago.
Just put some rubber grease on new o-ring before installing it.
Perfect thanks, yeah I’ve got the rad off right now so it’s easy to get at I just didn’t want to have to get my ac refilled after
Did you ever get that wired up? Did the ac sensor and it didn’t help, it’s running ok otherwise so I’ve just been living with it but I’d still like to fix it at some point, especially with winter coming
