Crunch Noise On Hard Brake
So this has been going on for a while. I don’t remember if it happened after something specific was installed but I’ve checked so many things that I’m out of ideas. The noise happens when I’m braking and only comes from the front right of the car. It also happens when I’m reversing for the first few feet. If I brake softly can come to a complete stop without the noise. But when I brake hard enough that the nose dips I hear it. It happens when I’m slowing to a stop, but also if I just hit the brakes hard enough while driving. At first I thought it was the H&R Coilovers but the noise is also happening with the Ohlins kit. Plus if you push the car up and down in the front to make it bounce, it’s silent. It never makes the noise going over bumps. JHM said they noticed it too and they confirmed the suspension and arms were all torqued to spec. I have the 034 upper control arms with probably about 8k miles on them. The dust boots need to be replaced but other than that they are fine I’m assuming. I replaced all of the lower arms with the HD upgrade set or whatever it’s called from JHM. I’ve replaced the inner and outer tie rods with HD tie rods. I have the 034 motor mounts which have maybe 8k miles on them. Finally, I have the Hotchkis sway bar with the 034 end links. The front right axle was rebuilt about 13k miles ago and the front right wheel bearing was just replaced. I also have the track density upper strut mounts. When it was still making noise after all of that I figured it’d disappear when I changed the brakes but it didn’t. I really thought it was going to be the brakes because the other day when it rained I wasn’t getting the sound at all regardless of how hard I braked. This has been so aggravating and I just want it to go away.
