Cutch and brake pedal pads. S5 MT
Has anyone installed aftermarket clutch/brake pedal pads? My concern is the clutch. How was the replacement pad attached to clutch lever? Where did you get the pads?
Thanks, Eric
15 S5 MT, 08 S6, 02 RT-10, 14 S-85 (Her’s) 53 120 (Hers too!) and a truck.
Clutch wise check out jhm they have a big 4.2 S5 program that includes lots of 3.0t parts I believe the clutch is one of the. The S5 seems to have come with the weakest clutches ever
Hey Eric,
I went with JHM’s stage IV clutch and LW flywheel about 8 months ago. Mine was failing after 2 years of supercharged V8 driving. I am so impressed by the smoothness, quickness, nearly identical engage point, and NO chatter!
It is very important that whomever installs it knows what they are doing because a bad install on the best clutch could be a disaster.
I also have the JHM light weight rotors and hawk pads which I am happy with as well
Good luck
you want to change your pedal pads? Isn’t that kind of rice for that car?
(says the guy with the carbon fiber wrapped bumper)
