I’m in the process of replacing the timing chain on my B7 S4, but when I installed the crankshaft locking tool it appeared as though cylinders number 2 and 8 were at TDC and there were no other notches for the tool when what I believe to be cylinder 1 is at TDC.
I was wondering if perhaps I’m looking at this wrong or if there’s some other issue here. The cylinder numbering is 1234 on the passenger side with 1 closer to the front of the car and 5678 on the driver side with 5 closer to the front of the car. Is this correct?
Yes
4 8
3 7
2 6
1 5
FRONT
You are goos man, cylinder 2 and 8 should be up.
Below is the engine with pin installed, it is confusing if you focus on cylinder orientation
http://i1294.photobucket.com/albums/b601/rs4elitist/PhotoNov1012041PM_zps023fd6d9.jpg
http://i1294.photobucket.com/albums/b601/rs4elitist/PhotoNov1012033PM_zps3b33ac40.jpg
This is Right. TDC is represented by cylinder 2 not cylinder 1 like in other cases.
Thanks guys.
