Hi guys, I’ve got an 06 B7 RS4 that I’ve had for about 12 months now. The performance of the car has always felt a little flat. I did some datalogging in summer, and saw that a pretty huge amount of timing was being pulled from 3k to 8k. Putting it down to our very hot/humid summers here in North Queensland, I put the datalogging on hold until winter.
Well, I’ve just done some more datalogging the other night, where ambient temps were about 19degrees celcius. My 3k-8k times improved from 11.34s to 10.81s, but I’m still showing timing retardation, and those acceleration times seem to be pretty far off what is normal for a stock car.
What IATs are you guys normally seeing when the timing is not being pulled?
IAT for summer run was ~45deg C
IAT for winter run was ~24deg C
Car is 100% stock at the moment. Feels like everything is running well, and I can feel the torque increase at around 5k rpm.
I’m unsure whether the car has ever had a carbon clean, though I suspect it hasn’t. It currently has 150 000kms on it. Would carbon buildup increase the propensity for the timing to be pulled?
Be interested to get some other thoughts from people who have done a bit of logging.
Cheers.
PS: Here is a copy of the summer and winter logs: https://www.dropbox.com/s/cqo4h1j7imhd21g/WintervsSummerLogs.xlsx
