Hi guys, I know this is an old thread, but thought I’d give a quick update. I’ve finally had enough time on holidays to do the carbon clean and install some JHM intake spacers. I’ve also replaced the valley pan gasket, and the two different oil filter housing seals as I was getting some pretty decent oil leaks from the valley area.
First, man, what a PITA job. I was definitely taking my time and couldn’t dedicate all of every day on it, but it still took 4 days from start to finish.
I went down the zip ties and oven cleaner route, and this was time consuming, but ended up working well after several soakings and scrapings.
Once the manifold came off, I can pretty much guarantee that this engine has never been cleaned. I’m up to 180k kms now, and the carbon buildup was unbelievable. I’ll post up some pics later once I upload, but several of the ports were totally occluded on the top and left hand sides of the port runners. There was really very little actual room left in the ports for air to flow. The build-up was way worse than any other pics I’ve seen in all my research (including 2ManyToys buildup with his leaking valve stem seals, and a pic from a South African RS4 for 160k kms on it). Having seen it with my own eyes, I really can’t believe the car was even managing to run, and run smoothly at that!
Anyway, once I had everything back together and buttoned up, cleared the codes from the sensors being unplugged, everything is running fine. Took it for a run around the block and holy sweet mother of god, there is a huge difference. I was unsure what to expect as plenty of people had a clean and didn’t notice anything, but it is extremely obvious in my case. Torque down low is much improved (spacers likely helping here), but top end is absolutely phenomenal now. I used to get an exhaust note change and a small pickup when the throttle opened up 100% at 5500rpm, but now it’s literally like a turbo coming on boost it’s that viscious!
I haven’t done any follow up datalogging yet, but I took 3 good back to back 3k-8k pulls at 20degC ambient temps for before after comparisons. I’m waiting to get another 20degC ambient to use the same stretch of road to run another 3 “after” runs to compare the carbon clean back to back. My gut is telling me I’m going to be seeing a lot less timing retardation and a pretty healthy boost to MAF volume, and hopefully a look in at an 8.x time.
I’ll definitely post up the pics and extra datalogging results once I have the info collated, as I’ve never found any objective and comprehensive before/after VCDS logging on a carbon clean anywhere on the net.
