Diagnostics displayed in german
Hi, took my 2009 s6 to a local vw/audi mechanic after the engine and epc lights turned on (my normal mechanic was closed because of holidays). But the new mechanic said their diagnostics is reporting things back in german instead of english. Is that something that can be switched back to english and how? Or is more likely the diag tool they are using?
First time ever hearing that and thought it was a weird thing for a mechanic to say… but just checking anyways…
Should be the diagnostic tool they are using – do you have access to a VCDS cable? If not, may be worth buying one or borrowing one from someone local.
Took it to another shop and got both hpfp replaced. Its running again! Happy to see no warning lights.
What was wrong with the HPFP units?
