Why: They commonly fail when people change their downpipes because of the increased exhaust flow. It is also required to remove the oxygen sensors when performing other repairs/modifications. I didn’t want to make two different DIYs for the front and rear oxygen sensors so I combined them into one DIY.
Previous steps required:
- Removing the MAF boot and top half of the engine air box. http://audirevolution.net/forum/index.php?topic=2919.0
- Loosening the coolant tank so that it can be moved around for clearance. http://audirevolution.net/forum/index.php?topic=2921.0
- Jacking up the front end and remove the belly pan - for the rear oxygen sensors http://audirevolution.net/forum/index.php?topic=2922.0
Parts Required:
- Oxygen sensors - if replacing and they are different from the front to back.
- Zip ties and a cutting tool like side cuts/dykes
Tools Required:
- Oxygen sensor specialty socket or a 22 mm wrench for the rear oxygen sensors
http://i284.photobucket.com/albums/ll37/Jimmybones777/20140902_190701_resized_zpsb0009dc6.jpg
- Long extensions and 3/8 drive ratchet
- Wiring terminal release tool - if replacing the rear oxygen sensors with factory replacement sensors
ECStuning sells a kit that is slightly more expensive then just one factory tool. http://www.ecstuning.com/Audi-B6_S4--V8/Tools/Electronic/ES11414/
http://c1552172.r72.cf0.rackcdn.com/188486_x600.jpg
Steps:
The steps are broken up into a and b sections for the front and rear oxygen sensors.
- Disconnect the electrical connector of the oxygen sensors. The electrical connectors are located on the plastic connector brackets on the cowl wall behind the MAF sensor/boot and coolant tank. The front oxygen sensors have black six pin connectors and the rear oxygen sensors have green or brown four pin connectors.
http://i284.photobucket.com/albums/ll37/Jimmybones777/20140902_190737_resized_zpsa8128827.jpg
http://i284.photobucket.com/albums/ll37/Jimmybones777/20140902_190723_resized_zps2fba5915.jpg
2a. Loosen the front oxygen sensors from the top of the downpipes. You have to look down the back of the engine to see the sensor bodies. I like to slide the oxygen sensor tool down the wires to the sensor body, then crack the sensors loose with extensions and the ratchet, turn the sensor bodies loose by hand, and pull the sensors out.
Passenger’s side front oxygen sensor:
http://i284.photobucket.com/albums/ll37/Jimmybones777/20140902_1857551_zpsa28b1871.jpg
Driver’s side front oxygen sensor:
http://i284.photobucket.com/albums/ll37/Jimmybones777/20140902_185824_zps2465e897.jpg
2b. Loosen the rear oxygen sensor bodies. I find it easier to use a 22 mm wrench then a oxygen sensor socket for loosening the rear oxygen sensors. The below picture shows a car with rear O2 sensor spacers so your car will probably not have the rear oxygen sensors spaced out so far.
http://nickscarblog.com/wp-content/uploads/2012/09/IMAG0485.jpg
3b. Remove the rear oxygen sensors.
Always label the oxygen sensors so that they are not mixed up when reinstalling. I can’t tell you guys how many times I have seen people ask why the check engine light comes on with oxygen sensor codes present after exhaust work is done. I have done it too so just go ahead and label your oxygen sensors.
The sensor wiring is usually attached to the transmission so you have to pull the wires up and free. If you are replacing the rear oxygen sensors then I have cut the connector off at the top and then pulled the sensor and wire out from the bottom rather than having to
4b. If you are replacing the rear oxygen sensors with factory replacements then you have to also replace the electrical connectors on the wiring harness side because the new sensors use generic black connectors instead of the original color coded (green and brown) connectors. To do that you need to slide the protective rubber wiring harness cover off the back of the harness side connector, use a pick tool or flat head screwdriver to pop the pink locking pin out of the inside of the new connector, use a wiring terminal removal tool to release the tabs of the wiring terminals, pull the wiring terminals out one at a time and swap them into the new connectors, you will hear a click when the terminals snap into place, and once all four wiring terminals are swapped over reinstall the pink locking pin and protective rubber wiring harness cover on the back of the connector.
http://i453.photobucket.com/albums/qq256/Tweaked2001/Audi%20Electronics/IMG_2661.jpg
http://c1552172.r72.cf0.rackcdn.com/190123_x600.jpg
http://i.ytimg.com/vi/5rlXZUvhEsQ/hqdefault.jpg
http://www.4130-products.com/step/wiring/terminal_05.jpg
http://www.4130-products.com/step/wiring/terminal_08.jpg
5b. Audi wanted to save money so they use generic replacement sensors with the longest possible length wires required so I like to zip tie the excess wiring out of the way.
