You can buy O2 spacers, or make your own by dremeling out a pair of spark plug defilers stacked on each other (both do the same thing, slightly recess the O2 sensor to make it that less air passes buy to make the car think that the precats are working fine). Only people who really do this are the ones debating not going to a JHM tune, but a large bit of performance from piggies/catless is being left on the table without a tune for the dp’s.
The rear O2’s only real purpose is helping set long term fuel trims. You’ll definitely throw a cel after about 60-80 miles, but you can clear it or just deal with it until you get a tune (which I’d say get the JHM tune).
I’d say just go ahead and order the tune, and deal with the CEL (or clear it) until you get the tune in and then you won’t ever have to worry about it again.
