I have a manual, with 90k. Over the past year and a half I have upgraded in this order, spulen rear diff mount, 034 snub mount (had shave to keep it from touching cage), 034 rubber motor and trans mounts. With each change it felt better for about a week or two and then it went back to the feel that I started with. Clunky, harsh and non smooth feeling. From everything I have read over the years, changing these things should make the shifts feel better not unchanged. Idk if I did something wrong with the installs or, if I still have a weak link somewhere.
