Driver door electronics don't work and 01331 code
So I got back to my car last night and none of the electronics in the driver side door work. The door won’t lock when I use the lock button on the key, the lights for the switches are all off, the windows won’t roll down, and I can’t control the mirrors. I also noticed that none of the windows work when using their respective switch in each door nor do they work with the key. All of the window switches in every other door are lit up and the sunroof still works. When I scanned the car with VCDS I got this:
01331 - Door control module - driver side (J386)
49-00 No communication
http://uploads.tapatalk-cdn.com/20160705/f16ff19e3fef6e498115d5309ed36ce3.jpg
Do I need to pull the door card? Is there a fuse I can check for this? Does this mean I need to order a new window switch? I ran through the list on the fuse panel and didn’t see anything that seemed related. Thanks in advance for any help.
