I had a request regarding my setup and stance. Weather has been shit lately until yesterday. Here are the pics:
http://i38.tinypic.com/20fyflz.jpg
http://i35.tinypic.com/1zp7k2d.jpg
http://i33.tinypic.com/143i0jn.jpg
looking great. love the deep sea blue.
what’s the story with your wheel offset and spacers setup? stance looks perfect.
Thanks!
I believe the wheels are 19x9 ET34 with H&R DRA 15mm and 20mm bolt on spacers the front and back respectively.
Wheels were made to fit a B6 S4 as aggressively as possible, and a S5. By the time I received them from modbargains/forgestar I had the S5. They were quite sunken in so I went with a pretty solid sized spacer and Im happy with the results. I even run the spacers with my stock winter wheel set up. Some of the negative consequences of the wide stance is the amount of tire spray up i get on the side of my car and due to the 15/20 sizes, less 5mm in the front increasing the understeer even more
spray up. excellent point. ugh. I just removed quite a bit of worm guts that were caked on the body behind the tires after driving in the rain. I guess that will get worse.
