I headed up to Enhanced Street Performance in Sterling, MA today to get a few pulls in. It was my first time dyno-ing a car and Dave and Justin took great care of me and my car. Overall had a ton of fun and got some good info.
Here’s the results:
1st pull - 3rd gear - 285.6/272
2nd pull - 4th gear - 306.2/270.7 (as you’ll see on the graphs when I upload them, the 306.2 occurred on a spike, and likely wasn’t legit)
3rd pull - 4th gear - 301.1/270.4
Weather Conditions: 66 degrees, 17% humidity, DA estimated using a calculator at ~922ft (elevation 508ft, temp 66f, altimeter setting 30.11, dew point 23f)
Specs on the car:
2005.5 S4 - MT
66k miles
up-to-date on all maintenance
mods: Fast Intentions 2.5" catted downpipes, Fast Intentions 2.5" catback with xpipe and 14" resonators, and a JHM Intake Manifold. NO TUNE. Also has 19" Neuspeed RS-10 wheels that shave a few lbs compared to stock. They’re probably 45lbs per wheel with tires.
Overall I was quite pleased with the results. I wanted to get a baseline before sending my ecu out to JHM. Now that I got it done, I can finally get my tune!
I’m not sure if 3rd gear pulls or 4th gears pulls are the norm for the S4, so maybe someone can provide some insight on that. Any thoughts, comments, recommendations or questions are welcomed.
And if someone could tell me how I can post a .pdf file I would greatly appreciate it. I tried to convert the pdf to an image and didn’t have much success.
Links to images since they’re so small below:
http://audirevolution.net/addons/albums/images/173862141.png
http://audirevolution.net/addons/albums/images/148606313.png
http://audirevolution.net/addons/albums/images/664448688.png
http://audirevolution.net/addons/albums/images/246376617.png
http://audirevolution.net/addons/albums/images/463767087.png
http://audirevolution.net/addons/albums/images/311761421.png
3rd Gear Graph & Results:
http://www.audizine.com/gallery/data/500/medium/treacy_s4_3rd_hp_-_png.png
http://www.audizine.com/gallery/data/500/medium/treacy_s4_3rd_results_-_png.png
4th Gear Pull #1 Graph & Results:
http://www.audizine.com/gallery/data/500/medium/treacy_s4_4th_hp_pull1_-_png.png
http://www.audizine.com/gallery/data/500/medium/treacy_s4_4th_pull_results_-_png.png
4th Gear Pull #2 Graph & Results:
http://www.audizine.com/gallery/data/500/medium/treacy_s4_4th_hp_pull_2_-_png.png
http://www.audizine.com/gallery/data/500/medium/treacy_s4_4th_pull_2_results_-_png.png
