Just figured I would share these, since I finally bothered to make some more runs. I made a few runs Saturday and discovered that I was missing MASSIVE power up top. Given the power loss started around 5,000rpm, I figured it must be the intake flap. Sure enough, it’s very tough to move by hand and was stuck in the low rpm position, but it moves (and stays where I put it no matter what). So I took her out again Sunday morning to make some runs with it in the high rpm position, to compare. Surprisingly, the loss in the low end was small, and honestly I didn’t feel a difference at all in the seat of the pants. But up top, I definitely felt and heard the difference with the flaps in high rpm position. Makes me wonder if removing the flaps altogether would really be that bad.
Anyway, here’s the graph:
http://a2.sphotos.ak.fbcdn.net/hphotos-ak-ash4/241936_10101140165665711_1483995129_o.jpg
Blue = stock (ignore torque spikes - RPM pickup was not good, as I was learning the GTechRR)
Green = piggies only, no other mods
Red = piggies, Magnaflow exhaust, JHM tune, intake flap stuck in low rpm position
Black = piggies, Magnaflow exhaust, JHM tune, intake flap stuck in high rpm position
Notes
- Car is a 2004 S4 Sedan 6MT. Bought with 56k miles, now has 65.8k miles.
- The Green line was performed at about 37F ambient temperature, while the Red and Black were at 74f and 71*f, respectively. All were created very very close to sea level and in dry weather.
- I’m sure everyone is aware that the GTechRR is pretty precise, but reads notoriously low.
- I also have trouble getting the tach reading perfectly; the Red and Black lines were run right into the rev limiter to see what would happen, so that should be pretty indicative of around 7200rpm or so in reality, not 6700rpm.
- If you dyno a GTechRR (in second gear) back to back with a DynoJet 248c, you’ll find that it reads about 20% lower very consistently. At least that has been my experience, as I have done this several times with other vehicles. This would put me very nearly at 300whp, but no cigar. Not surprising to me, since this car laid down 269whp when I first bought, bone stock.
- I also did not average multiple runs. For those of you not running intake manifold spacers, I’m sure you’ve heard about heat soak. Every run I make is at least 3-5hp less than the last, no matter what the ground or wind is doing. The only way to fix it is to drive for a few miles without stopping, then quickly stop and make the run. Since this is a GTech, this isn’t always possible, as traffic gets in the way. So I find a flat road (flat as confirmed by the G-sensors when stationary, as they will show you what is and isn’t flat) and go with the best result after a few passes back and forth, trying to give it some cooling time in between.
Conclusions:
(considering a healthy engine as a proper mix of the Red and Black lines, with changeover at ~4700rpm):
- Piggies made the ONLY difference below 4,400rpm - the exhaust and even the stupendous JHM tune gained nothing, though some small gain probably would have showed had I made the Green run at the same temp as the new Red and Black runs. Obviously, above that, the tune is making gigantic power over stock, with the exhaust probably playing a significantly smaller part than the tune.
- The crossover of the Red and Black lines shows where the ideal flap changeover point is - right about 4,400rpm. The tach signal is a little off on this graph, so 4,400rpm indicated is more like ~4,600-4,800rpm in reality. I seem to recall Jay&JHM stating that their crossover is at 4,700rpm, so they’re pretty much tits, as expected.
- The peak power engine speed hasn’t really changed at all with these mods, and neither has the torque peak engine speed. The numbers next to the graph say it has, but the torque in that area is basically flat, so minor undulations cause the absolute peak number to be at a different speed.
- Gains over stock are about 20ftlb from 2,500rpm to 3,500rpm, peak gain of 30ftlb at 5,000rpm, and still 20ft*lb from 6,000rpm up. Overall, this is a much, much quicker car that plainly makes a big difference in area under the curve. For the limited money spent, this is definitely a big win. Peak gain of about 30whp over stock, and that’s still with the GTechRR’s severely deflated numbers.
-piggies = free (DIY)
-exhaust = $675 I think, shipped
-tune = $560 or so shipped both ways
-total = $1,235 - The losses in the low end from having the flaps in high rpm position (Black line) were really not bad at all compared to the low rpm position (Red line). I thought I had read somewhere that JHM had tried leaving the flaps in high rpm position and lost 55ftlb. These results make me want to see what happens if I totally remove the flaps and somehow close off the low rpm runners. They look like a massive obstruction to the high rpm runners when they’re in low rpm position, so I’m rather sure I would see even bigger gains in the top end with them completely removed. Perhaps JHM saw a loss of 55ftlb when removing the flaps completely because both sets of runners were open? It would be an interesting test. If I ever find myself with a spare intake manifold, I’ll be keen to test block off the low rpm runners and removing the flaps completely. I know, I’d need a block-off plate for the front of the manifold, yada yada.
I’m not planning on spending any real money on her any time soon in the name of performance, though I do have a couple cheap projects planned and some minor maintenance/repairs to work on (including freeing up the flap mechanism). I do wonder, however, how much torque the stock B6 clutch can hold. I don’t launch the car, as I don’t see the point, but at some point the torque it can hold will be outrun by the torque the engine can produce, and the clutch disc will just become a polishing wheel. I’d love to know about where that point is. Rephrased, I’d love to know if my next performance purchase can be catless downpipes, or if it needs to be a clutch first.
