Electrical Gremlins
Hi All,
I’ve been fighting some issues over the past couple of years, and I’m finally ready to tackle them. I’ve documented a few things before, but I want to start fresh and get this fixed up.
Main issues:
  • ESP light makes it so we can’t drive our girl.
  • Airbag light.
Sub issues:
  • Passenger door stopped locking
  • Headlight error, lights no longer track
  • One backup sensor failed
  • Low oil dash notification
  • Low coolant dash notification (goes away after about 15 seconds of runtime)
For the ESP fault, this is the biggest cause of concern. The VCDS log (as posted below) says that there is an angle sensor 2 error for the TB. I have swapped the TB’s and got the same error for the same TB, so I’m 99% sure it’s wiring. I have also replaced the ends (and even twisted as per the Audi bulletin) with no success. I’ve pulled both ECU’s and have checked the contacts and looked for pinch or kinked wired in the harness between the firewall and the ECU’s. Where would other points of failure be for the harness? Anything else I can test before I start digging into copper?
Also, the ESP light resets if I unplug and re-plug the TB connectors. Just a pain to do if the engine is warm and it’s rainy outside.
The Air bag light appeared on the drive home after the Airbag recall was done. I got into it with the dealer because they said there was rodent damage to the wires, and wanted to pull the front end of the car apart on my dime. I had the tech show me and the service writer where the damage was and he couldn’t produce it, service writer still wanted to proceed even though there was no signs of the damage. VCDS says that both front crash sensors are bad. Possible, yes, probable, not really? Maybe a rodent did something in there, but when I the front off to replace the radiator I saw no damage to any wires up there. Is there a voltage I can test with my multi-meter?
The passenger door just started after we started driving the car again after she was sitting for a while. I think a new door module is probably needed. No big deal, not a deal breaker right now.
Headlight error is caused by bad wires, I need to take the time to open the headlight and replace all the cracked wires in there (both sides are equally bad…)
Backup sensor - VCDS reports a bad sensor, probably correct.
Low oil - I replaced the oil sensor once, error still persisted. I can replace it again, if that’s really the culprit.
Low coolant - replace the sensor and reservoir is my next task. Coolant is always perfect height, even after running.
Any help is gladly appreciated, and have beer and whiskey if you live in the PNW. I really miss driving this car, but I don’t want to feel that I can only safely drive 10 - 15 miles before something prevents me from going highway speeds.
Also, worth noting is that we disabled the tire pressure system, removed the fuse and re-coded from VCDS.
One last thing, is there a VCDS label file for these cars?
Peace out, brothers.
VCDS log will be in a reply, forums are complaining that it’s too long…
Removed all the modules that passed to save length.
Also, I replaced all the coil packs two years ago with ones from ECS, and I still get misfires sometimes when it’s cold outside.
Tuesday,25,January,2022,17:07:56:34008
VCDS – Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
VIN: WAUGN74F27N126927 License Plate: 123
Mileage: 347240km-215764mi Repair Order:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 11 31 15 16 17 19 1E 36 37 42 46
47 4F 52 53 55 56 61 62 67 6C 72 76 77
VIN: WAUGN74F27N126927 Mileage: 347240km-215764miles
03-ABS Brakes – Status: Malfunction 0010
07-Control Head – Status: OK 0000
0F-Digital Radio – Status: Malfunction 0010
15-Airbags – Status: Malfunction 0010
19-CAN Gateway – Status: Malfunction 0010
1E-Media Player 2 – Status: OK 0000
52-Door Elect, Pass. – Status: Malfunction 0010
55-Headlight Range – Status: Malfunction 0010
56-Radio – Status: OK 0000
61-Battery Regul. – Status: OK 0000
76-Park Assist – Status: Malfunction 0010
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F1 910 552 A HW: 4F1 907 552
Component: 5.2L V10/4V FSI ª0040
Revision: 59H14— Serial number:
Coding: 01050009190F0160
Shop #: WSC 23190 444 53218
VCID: 221DEADFD8C7BC9B915-8076
VINID: 9D19577871160877810862421CD812A08B
5 Faults Found:
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 57
Reset counter: 255
Mileage: 346027 km
Time Indication: 0
Date: 2021.05.17
Time: 13:58:17
         Freeze Frame:
                RPM: 1268 /min
                Load: 20.0 %
                Speed: 0.0 km/h
                Temperature: 70.0°C
                Temperature: 43.0°C
                Absolute Pres.: 990.0 mbar
                Voltage: 11.303 V
000545 - Angle Sensor 2 for Throttle (G188)
P0221 - 008 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 0
Fault Frequency: 7
Reset counter: 255
Mileage: 346791 km
Time Indication: 0
Date: 2021.11.12
Time: 11:11:46
         Freeze Frame:
                RPM: 1896 /min
                Load: 49.8 %
                Speed: 39.0 km/h
                Temperature: 99.0°C
                Temperature: 38.0°C
                Absolute Pres.: 1010.0 mbar
                Voltage: 13.335 V
005476 - Throttle Actuator (J338)
P1564 - 002 - Under-Voltage during Basic Setting
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 347065 km
Time Indication: 0
         Freeze Frame:
                RPM: 106 /min
                Load: 100.0 %
                Speed: 0.0 km/h
                Temperature: 57.0°C
                Temperature: 19.0°C
                Voltage: 9.525 V
005703 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 002 - - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 347089 km
Time Indication: 0
Date: 2022.01.04
Time: 07:38:33
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 4.0°C
                Temperature: 8.0°C
                Absolute Pres.: 1000.0 mbar
                Voltage: 11.303 V
P1923 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 347231 km
Time Indication: 0
Date: 2022.01.25
Time: 16:41:29
         Freeze Frame:
                RPM: 208 /min
                Load: 56.8 %
                Speed: 0.0 km/h
                Temperature: 73.0°C
                Temperature: 34.0°C
                Voltage: 10.160 V
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Coding: 0020920
Shop #: WSC 02325 785 00200
VCID: 313F15938D21170318F-8064
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 58
Reset counter: 217
Mileage: 346027 km
Time Indication: 0
Date: 2021.05.17
Time: 13:58:18
         Freeze Frame:
                Hex Value: 0x04C0
                Hex Value: 0x4006
                Hex Value: 0x0025
                Hex Value: 0x01A1
                Hex Value: 0x00FF
15 Faults Found:
P1653 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 58
Reset counter: 255
Mileage: 346027 km
Time Indication: 0
Date: 2021.05.17
Time: 13:58:17
         Freeze Frame:
                RPM: 1263 /min
                Load: 19.6 %
                Speed: 0.0 km/h
                Temperature: 70.0°C
                Temperature: 43.0°C
                Voltage: 11.303 V
P0300 - 001 - - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 0
Fault Frequency: 12
Reset counter: 255
Mileage: 346044 km
Time Indication: 0
Date: 2021.05.18
Time: 17:15:42
         Freeze Frame:
                RPM: 1136 /min
                Load: 40.8 %
                Speed: 0.0 km/h
                Temperature: 39.0°C
                Temperature: 30.0°C
                Voltage: 12.954 V
012342 - Throttle Controller 2 (J544)
P3036 - 002 - Low Voltage at Basic Setting - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 346190 km
Time Indication: 0
Date: 2021.06.10
Time: 18:01:57
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 53.0°C
                Temperature: 30.0°C
                Voltage: 9.144 V
012328 - Angle Sensor 2 for Throttle Drive 2 (G298)
P3028 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 7
Reset counter: 255
Mileage: 346280 km
Time Indication: 0
Date: 2021.06.16
Time: 18:34:29
         Freeze Frame:
                RPM: 1385 /min
                Load: 19.6 %
                Speed: 37.0 km/h
                Temperature: 91.0°C
                Temperature: 39.0°C
                Voltage: 13.843 V
000772 - Cylinder 4
P0304 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 8
Reset counter: 255
Mileage: 346490 km
Time Indication: 0
Date: 2021.07.07
Time: 07:33:53
         Freeze Frame:
                RPM: 1144 /min
                Load: 45.5 %
                Speed: 0.0 km/h
                Temperature: 30.0°C
                Temperature: 21.0°C
                Voltage: 13.335 V
000777 - Cylinder 9
P0309 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 9
Reset counter: 255
Mileage: 346490 km
Time Indication: 0
Date: 2021.07.07
Time: 07:33:53
         Freeze Frame:
                RPM: 1144 /min
                Load: 45.5 %
                Speed: 0.0 km/h
                Temperature: 30.0°C
                Temperature: 21.0°C
                Voltage: 13.335 V
000769 - Cylinder 1
P0301 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 346525 km
Time Indication: 0
Date: 2021.07.14
Time: 08:13:02
         Freeze Frame:
                RPM: 1147 /min
                Load: 44.7 %
                Speed: 0.0 km/h
                Temperature: 30.0°C
                Temperature: 21.0°C
                Voltage: 12.573 V
001593 - Throttle Body Actuator Bank 2 (J544)
P0639 - 002 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 10
Reset counter: 255
Mileage: 346526 km
Time Indication: 0
Date: 2021.07.14
Time: 08:19:20
         Freeze Frame:
                RPM: 628 /min
                Load: 26.7 %
                Speed: 0.0 km/h
                Temperature: 58.0°C
                Temperature: 24.0°C
                Voltage: 13.589 V
000771 - Cylinder 3
P0303 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 346734 km
Time Indication: 0
Date: 2021.11.08
Time: 18:27:56
         Freeze Frame:
                RPM: 1170 /min
                Load: 45.5 %
                Speed: 0.0 km/h
                Temperature: 27.0°C
                Temperature: 18.0°C
                Voltage: 13.335 V
004906 - Knock Sensor 3 (G198)
P132A - 008 - Electrical Malfunction in Circuit - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 346858 km
Time Indication: 0
Date: 2021.11.12
Time: 12:09:35
         Freeze Frame:
                RPM: 1846 /min
                Load: 40.4 %
                Speed: 85.0 km/h
                Temperature: 94.0°C
                Temperature: 21.0°C
                Voltage: 13.081 V
004899 - Knock Sensor 4 (G199)
P1323 - 002 - Signal too Small - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 346862 km
Time Indication: 0
Date: 2021.11.12
Time: 12:15:06
         Freeze Frame:
                RPM: 2595 /min
                Load: 31.4 %
                Speed: 34.0 km/h
                Temperature: 93.0°C
                Temperature: 24.0°C
                Voltage: 12.573 V
000775 - Cylinder 7
P0307 - 001 - Misfire Detected - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 346862 km
Time Indication: 0
Date: 2021.11.12
Time: 12:15:09
         Freeze Frame:
                RPM: 2039 /min
                Load: 54.9 %
                Speed: 42.0 km/h
                Temperature: 92.0°C
                Temperature: 23.0°C
                Voltage: 12.700 V
000774 - Cylinder 6
P0306 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 346862 km
Time Indication: 0
Date: 2021.11.12
Time: 12:15:17
         Freeze Frame:
                RPM: 2665 /min
                Load: 30.2 %
                Speed: 56.0 km/h
                Temperature: 91.0°C
                Temperature: 21.0°C
                Voltage: 12.700 V
000784 - Cylinder 10
P0310 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 346862 km
Time Indication: 0
Date: 2021.11.12
Time: 12:15:17
         Freeze Frame:
                RPM: 2665 /min
                Load: 30.2 %
                Speed: 56.0 km/h
                Temperature: 91.0°C
                Temperature: 21.0°C
                Voltage: 12.700 V
000776 - Cylinder 8
P0308 - 001 - Misfire Detected - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 346862 km
Time Indication: 0
Date: 2021.11.12
Time: 12:15:17
         Freeze Frame:
                RPM: 2665 /min
                Load: 30.2 %
                Speed: 56.0 km/h
                Temperature: 91.0°C
                Temperature: 21.0°C
                Voltage: 12.700 V
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 K HW: 4F0 959 655 D
Component: 7G AIRBAG AUDI8RH30 0400
Revision: 02H30000 Serial number: 003BMD0104X1
Coding: 0014151
VCID: 2F3B13EB9B1501F30EB-807A
Subsystem 1 - Part No: 4F0 910 339 A
Component: BF-Gewichtsens. H02 0050
Subsystem 2 - Serial number: 6332CSME16780753+
Subsystem 3 - Serial number: 6342CSME167807540
Subsystem 4 - Serial number: 6352QSME2150367DE
Subsystem 5 - Serial number: 6362QSME22124415%
Subsystem 6 - Serial number: 63734SME1D643309/
Subsystem 7 - Serial number: 63834SME210B212DY
2 Faults Found:
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
014 - Defective - Intermittent - MIL ON
01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B071178021
Coding: F5D1DEF7707A06
VCID: 6C81C4E76A83BAEB6B9-8038
1 Fault Found:
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 217
Mileage: 347241 km
Time Indication: 0
Date: 2022.01.25
Time: 17:01:55
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01034439580000
Coding: 4618269
Shop #: WSC 02335 785 00200
VCID: 2E050EEF9C1F08FB05D-807A
1 Fault Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 217
Mileage: 317687 km
Time Indication: 0
Date: 2017.12.04
Time: 10:30:39
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00-00000
Coding: 0051947
Shop #: WSC 02327 785 00200
VCID: 2C0104E7AA037AEB2B9-8078
1 Fault Found:
02115 - Locking Unit for Central Locking
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 217
Mileage: 347241 km
Time Indication: 0
Date: 2022.01.25
Time: 17:01:52
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000255
VCID: 290FFDF3A5F16FC3D0F-807C
Subsystem 1 - Part No: NOSUBSYSTEM
Component: AFS-Modul links
Subsystem 2 - Component: AFS-Modul rechtsH02 0020
3 Faults Found:
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 217
Mileage: 347240 km
Time Indication: 0
Date: 2022.01.25
Time: 17:01:53
01042 - Control Module; Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 217
Mileage: 347240 km
Time Indication: 0
Date: 2022.01.25
Time: 17:01:53
02233 - Left Headlight Power Output Stage (J667)
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 217
Mileage: 347240 km
Time Indication: 0
Date: 2022.01.25
Time: 17:01:54
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06230704106677
Coding: 0021306
Shop #: WSC 131071 1023 2097151
VCID: 270BFBCBB3E559B3C6B-8072
1 Fault Found:
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 25
Reset counter: 197
Mileage: 345975 km
Time Indication: 0
Date: 2021.05.12
Time: 17:16:49
End----------(Elapsed Time: 02:26, VBatt start/end: 13.7V/13.6V)-----------
Hey not sure if this is relevant but ever check the relays? My 5.2 had a flooded history since i got it from auction i took my a year of absolute hell to find out that literary every relay under the steering wheel was fried. So the car would stall after like 10 to 15 mins with esp fault or start acting up and i would turn it back on after and it would for some time and gradually got worse to the point to where it wouldn’t start at all sometimes. Might be worth a shot
I have had those as well.
ESP light would suddenly light up and car would go into limp mode when I did a hard acc.
Found out that TB connector was the issue. When it happened I had to disconnect/reconnect 3-4 times and it worked again for a couple of days.
When I took the time to thoroughly clean the connector it stopped and has not been an issue since… 1 year and counting.
Front crach sensors do fail. I have replaced one of them. Bought 2 just in case :wink:
The headlight issue I also currently have but I don’t see any cracked wires. Looking for a howto for this job. Please share if you have info on doing this :sweat_smile:
I have periodic sensor fails but I found out it’s the connector behind the bumper. It’s oxidation of the pins in my case.
My oil level sensor also failed. Bought an aftermarket sensor and it worked again.
I also have noticed that it’s quite important to have car reasonably level and check level when oil is at operating temp, 2 min. after engine stopped.
Otherwise level might not be correct.
Hope you get it all sorted :crossed_fingers:
I saw your post on relays when I was doing a search of the forums. I’ll re-read that again and try re-seating the relays this morning :crossed_fingers:
Thanks for the reply, I have a feeling that I might need to redo my connections again. The new connectors did help things for a bit, but then it started degrading again. Do you know of a good place to get connectors? I bought mine off of amazon, and the one thing I didn’t like about them was the wire size was all the same heavy gauge, instead of heavy gauge for the power and then light gauge for the signal, as per factory.
I’ll order a couple of impact sensors. I just thought it was weird that they both went at the same time?
The for the headlight, I posted a question and got a response. I figured I’d take over the dining room table for a week to get it all sorted out.
My driveway is on a slight incline, 16" rise to 10’ run, I guess it could cause the oil sensor to fault? But I still have the oil alert when I start the car from work as well and it’s a perfectly flat parking lot. I’ll check the oil after two minutes after driving, but I have a feeling it may be sensor or wire related. I still get the error after a oil change, and I know for sure the oil level is slightly higher than expected at that point.
The parking sensor, how hard is to to get to the connector?
Thanks for the reply! :v:
One place to check for sure if you haven’t already is compartment under the ecus. There you’ll find the ecu power relay and big fuse prone to contact issues.
Sorry 2nd image was mistakenly sent
The box looked dry, but the relay was defiantly used. I cleaned the contacts but I have a new one on order from VW/Audi. Thanks for the reply!
