Hey guys I have my newer audi s6 2008 120k is having electrical hell just like my 2007 one back a while ago.
The relays in the engine bay on the driver side the one for the fuel pump and ecm power supply relay were getting hot and stalling the car. It would turn off and not try to start up until it cooled. I confirmed this by immediately swapping it out and it started instantly. They no longer seem to get hot anymore.
Only the relays under the driver seat the terminal 15 relay and ecu power supply relay are both getting hot. I did swap them out with aftermarket one and it got hot again. I plan on trying genuine ones to see what happens.
I didn’t get to scan the car yet with a ross tech but the only obvious code with my hand scanner under engine 1 is engine mount on the passanger side that is open circuit. The wire is definitely fine to it but I’m pretty sure the mount is bad from the obvious shaking on that side
Ps relays act up after hour and 30 mins of driving
Any help would be greatly appreciated it!
