Electronics Cutting Out When Reving From Low Idle
Forgive me for all these posts as a new member, but as a V10 owner with no previous experience with these cars, when I can’t find an answer through the search, you can bet I’m gonna ask. ;D
So, as the subject says, let’s say I’m pulled up at a light and there’s a 5 series BM next to me, obviously I have to assert my dominance. However, when I rev the engine from an Idle, all electronics in the car cut out. I will post a video link.
(I should note that this issue is also unpredictable…sometimes it does it every time, other times I can’t even get it to do it.)
In this video, the instrument cluster actually stays lit, which normally even that cuts out. Watch the radio and all the red LEDs for the controls. Right around the 9-10 second mark.
https://youtu.be/h7MZcH3V1Fs
Everything boots right back up (Blutooth takes a min) and I obviously don’t get any codes from this. Only does it from a dead idle. I feel like this isn’t how its supposed to work. Anyone else seen this before? I’m thinking maybe alternator isn’t performing at tip top performance anymore, but then again, I’ve never seen this happen in a car I’ve owned.
