Engine code help
So in the last few days the car has not been starting on the odd occasion. Only really happens after I start the car and shut if off then try to start it again - usually cause my bluetooth has not connected. I had a similar engine not starting issue when we had the car in Europe and turned out the Main Relay was stuffed. This time I ran the VAG-COM tonight and I don’t really know what to make of it, so any guidance would be great!
I cleared the codes, and interestingly the car is back to it’s “jerky/hesitant” ways when I first got the JHM tune. I guess I have had the tune for about 3-4 months and of late it had started to really smooth out, now it’s back again.
17 Faults Found:
000642 - Fuel Injector #8 (N86)
P0282 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 4
Mileage: 120695 km
Time Indication: 0
Freeze Frame:
RPM: 181 /min
Load: 25.1 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 27.0°C
Absolute Pres.: 990.0 mbar
Voltage: 11.430 V
005490 - Left Engine Mount Solenoid Valve (N144)
P1572 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 120695 km
Time Indication: 0
Freeze Frame:
RPM: 200 /min
Load: 24.3 %
Speed: 0.0 km/h
Temperature: 48.0°C
Temperature: 27.0°C
Voltage: 10.922 V
005157 - EVAP Purge Valve (N80)
P1425 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 120695 km
Time Indication: 0
Freeze Frame:
RPM: 181 /min
Load: 25.1 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 27.0°C
Voltage: 11.430 V
000609 - Fuel Injector #1 (N30)
P0261 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 120695 km
Time Indication: 0
Freeze Frame:
RPM: 181 /min
Load: 25.1 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 27.0°C
Voltage: 11.430 V
000624 - Fuel Injector #4 (N33)
P0270 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 120695 km
Time Indication: 0
Freeze Frame:
RPM: 181 /min
Load: 25.1 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 27.0°C
Voltage: 11.430 V
000627 - Fuel Injector #5 (N83)
P0273 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 120695 km
Time Indication: 0
Freeze Frame:
RPM: 181 /min
Load: 25.1 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 27.0°C
Voltage: 11.430 V
005494 - Right Engine Mount Solenoid Valve (N145)
P1576 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 120695 km
Time Indication: 0
Freeze Frame:
RPM: 200 /min
Load: 24.3 %
Speed: 0.0 km/h
Temperature: 48.0°C
Temperature: 27.0°C
Voltage: 10.922 V
005234 - EVAP Leak Detection Pump
P1472 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 120695 km
Time Indication: 0
Freeze Frame:
RPM: 181 /min
Load: 25.1 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 27.0°C
Voltage: 11.430 V
005173 - Secondary Air Pump Relay (J299)
P1435 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 120695 km
Time Indication: 0
Freeze Frame:
RPM: 181 /min
Load: 25.1 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 27.0°C
Voltage: 11.430 V
000615 - Fuel Injector #3 (N32)
P0267 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 120695 km
Time Indication: 0
Freeze Frame:
RPM: 181 /min
Load: 25.1 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 27.0°C
Voltage: 11.430 V
005153 - Secondary Air Injection Solenoid Valve (N112)
P1421 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 120695 km
Time Indication: 0
Freeze Frame:
RPM: 181 /min
Load: 25.1 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 27.0°C
Voltage: 11.430 V
000630 - Fuel Injector #6 (N84)
P0276 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 120695 km
Time Indication: 0
Freeze Frame:
RPM: 181 /min
Load: 25.1 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 27.0°C
Voltage: 11.430 V
000087 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
P0057 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 120695 km
Time Indication: 0
Freeze Frame:
RPM: 181 /min
Load: 25.1 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 27.0°C
Voltage: 11.430 V
000055 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0037 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 120695 km
Time Indication: 0
Freeze Frame:
RPM: 181 /min
Load: 25.1 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 27.0°C
Voltage: 11.430 V
000612 - Fuel Injector #2 (N31)
P0264 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 120695 km
Time Indication: 0
Freeze Frame:
RPM: 181 /min
Load: 25.1 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 27.0°C
Voltage: 11.430 V
000633 - Fuel Injector #7 (N85)
P0279 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 120695 km
Time Indication: 0
Freeze Frame:
RPM: 181 /min
Load: 25.1 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 27.0°C
Voltage: 11.430 V
000258 - Mass Air Flow Sensor (G70)
P0102 - 002 - Signal too Low - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Mileage: 120695 km
Time Indication: 0
Freeze Frame:
RPM: 220 /min
Load: 23.1 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 27.0°C
Voltage: 11.430 V
That is a lot of short to ground faults at a slow cranking speed. I would start by looking at the global things like the main fuses, relays, and ECM in the ECM box. Make sure everything is connected properly, look for burn marks on the relays, and do voltage drop tests with a volt meter on the fuses with the engine running. You may also want to call JHM in case something came loose inside the ECM.
Looks like a main harness has been pinched or chafed, makes sense with the short to grounds everywhere. Did you send out out your ecu to JHM or did they remove it? I would check any exposed wiring or for a harness that was misrouted and has rubbed through the protective shielding. Also think it would be a good idea to pull your ecu cover to make sure you didn’t pinch any wires.
Hey, has it been figured out by now where the errors are coming from? Unfortunately, my S4 is now having exactly the same issues.
Did you check the fueses?
I’d start by clearing all of the codes and then take it for a short drive and see what codes come back first.
So the issue occurred only once.
The main problem the S4 has is the ESP error P1857 “engine load signal – implausible signal.”
After that, the mass airflow sensor error appears: “signal implausible.”
All fuses are intact.
The mass airflow sensor was replaced with a genuine original part, and the wiring was tested. Everything there is fine.
I was hoping that the starting problem and the many ground fault errors could have been a clue to the actual underlying problem.
