Engine code P0368 Camshaft position sensor B Circuit High Bank 1
Over the past few months I have had maybe 5-10 occurrences of a “Do not exceed 6000 rpm” warning with EPC light. It all disappears within 5 seconds. These happen at low speed and even at idle. This seems to NEVER have happened at any engine speed over 3000rpm. Code reader gives me P0368 Camshaft position sensor B Circuit High Bank 1 message. I didn’t have any Check Engine light until two weeks ago, and that went away after 2 days.
What do I think about this, and what about my car itself? My car is used regularly but not like a track car at 7500 rpm every day! I have just about 62,000 miles now, or just over 100k km. I have NOT had a carbon cleaning yet. Oil changes about 5000 miles, once a year (that’s as much as it gets used). All other maintenance done when scheduled, like spark plugs and all other fluids.
I am due for an oil change at this time, and I have considered to ask for a carbon cleaning to be performed at the same time. Something else suggested was to clean the throttle bodies, so that would be another easy task. Perhaps two camshaft sensors should be swapped to test them, but I think one is much more difficult to access.
In any case, if anyone has had this experience as well as a solution, I would like to hear about it.
I put my Rosstech VCDS on the car and got additional VAG codes 4511 and 5533. I have an appointment with my local Euro specialist on Monday so I will let them do a bit of investigation. Initial thoughts and hopes are for an electrical problem, so perhaps inspecting the wiring or swapping a pair of sensors will be the first efforts.
I have the same issue. Carbon clean done vvt solenoids replaced and all 4 cam sensors replace. Oem. My car doesn’t get driven much. Once the car is up to temp they go away. If I drive the car say, 3 days or 2 consecutively, it doesn’t come back.
Read a post somewhere a while back that the wires to the cam sensors are somewhat resistive type and can degrade over the years, hence the fault. You could replace the wiring loom, but it’s costly. I’ve just learned to live with it and it’s been 4 years with zero issues.
In saying that, yours could be something different. Just thought I’d share my bit.
Many parts of the wiring loom are available separately. https://www.ilcats.ru/?brand=audi&function=getParts&market=USA&model=RS5&modelcode=695&year=2014&group=9&subgroup=971&part=971081&language=en
First thing would be to pull out the engine wiring diagram and unplug from the ECU and start checking each connection for continuity. Obviously starting with all of the timing sensors since it sound like you have replaced all of those.
Thank you for your reply. In my case, have not yet replaced the cam position sensors, but that is going to be my first step. I have pulled the electrical connections (at the sensors) and re-plugged each just to ensure there was no “dodgy” connection, but that did not change anything. The warning comes up typically only once a day, with a 25km (~18 mile) journey morning and afternoon, and some days no warning at all. I drove over 250 miles yesterday and I had one warning event…
I moved the wires to the sides, outward over the lift brackets, since they get less hot from the engine there. Also I cleaned the connectors with electrics cleaner spray. Fingers crossed.
Thanks for your comments on that. I’ll pull the right side air filter box and look at what you mention for moving the wires. It’s winter weather here but every couple of days I still might get a warning, typically at idle. I have not swapped the sensors yet or ordered new ones. But those activities will come.
Okay, so it is 12 months later, and I have been living with regular Check Engine warnings of “Do not exceed 6000 rpm” since. Today I finally pulled the right side air filter box and TRIED to remove or at least loosen the metal shield that blocks access to the exhaust bank Cam Position Sensor. What a struggle! The bolts attaching that shield are extremely difficult to access. I tried… Instead, I grabbed tin snips and cut down a section of that shield and bent it back. That was done to allow access to the Torx30 bolt holding the sensor in. I then swapped both sensors on the right side, and plugged them in. Took a 10 minute drive and got a warning near the end of my drive. Fingers crossed that the code is different… IT IS!!!
I have gone from a P0368 (Bank 1 sensor B) to a P0343 for sensor A. Both about High Voltage Detected, but the error is following the sensor itself! I have a brand new replacement waiting, so it goes in tomorrow. Hopefully that is the end of the story.
Wouldn’t that be great if it finally solves your problem. Please make sure the sensor isn’t a Chinese made replacement, so many are today.
I waited a week with the original CPS in their “swapped” positions until I got another warning about “Do not exceed 6000 RPM” and I read the codes. So, again a P0343, up top. The original exhaust location one that was complaining regularly for the last year… So, a week ago, I replaced that sensor (now up top of course!) and there have been zero faults since. One week is not long, so I will keep going. The replacement was in an Intermotor box that I did not inspect carefully so I am not sure if it is European or Chinese in origin. I might still have the box!
