Engine died
Hopefully its not as bad as the title suggests… Coming home from a snowboarding trip this morning my engine died on the highway while cruising at about 70mph. I was half asleep, thinking about how shitty of a Monday it was going to be and then suddenly the car lost all power. I IMMEDIATELY pushed in the clutch, put it in neutral and the engine shut down instantly. All the electronics were still on. There was no CEL, odd noises or basically (further explanation to come) any warning prior to this happening. Luckily there was an exit 500 feet away that I was able to coast down and find a safe-ish place to pull over. Checked everything out under the hood and all seemed normal. Towed it back to my shop, scanned it and here’s what came up…
Readiness: 0000 0001
Monday,06,January,2014,12:54:14:42923
VCDS Version: Release 11.11.6 (x64)
Data version: 20121223
Kelsey’s Auto Body Inc.
            Address 01: Engine       Labels: 079-910-560-BBK.lbl
Control Module Part Number: 8E2 910 560 C HW: 8E2 907 560
Component and/or Version: 4.7L LC/93+JHM G 0010
Software Coding: 0007711
Work Shop Code: WSC 06325 000 00000
VCID: 275706F2964ABF20411
1 Fault Found:
000802 - Engine Speed Sensor (G28)
P0322 - 004 - No Signal
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 1
Mileage: 139969 km
Time Indication: 0
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 105.0 km/h
                Temperature: 96.0°C
                Temperature: 15.0°C
                Absolute Pres.: 990.0 mbar
                Voltage: 13.716 V
On my way up north I noticed while cruising the tach was bouncing a little bit but actual RPM’s were not fluctuating. Didn’t think much of it. The other minor problem I have been having is a intermittent skip and hesitation while under medium acceleration around 3-4k rpm’s. When it happens it is very noticeable and there is an audible pop in the exhaust note. Anyone have this sensor go bad before? It’s only a $125 sensor but am wondering if something else could be wrong and if I should do any further diagnosis before ordering it.
