Hey guys, I’m considering dropping the motor to perform engine out maintenance and I don’t have the skill set to do this myself.
How much will it cost to do this?
Any recommendations on reputable shops?
Open to all options at this point.
Thanks.
Thanks.
I think the cost will make you do it yourself like I did lol they told me it was 3k alone to remove the engine so who knows how much it’ll be with whatever maintenance they do to it
I’m located in Pittsburgh so I can’t recommend a shop, but I recently had a valve spring fail and mine is currently having the engine dropped to replace it. I was quoted around 2k from a local reputable shop charging $120 per hour. If I had the correct tools and a lift I would have attempted the drop myself, but it was a no brainer once I found I didn’t have to take it to a dealership. I’m always wary of independent shops as these engines are finicky so be sure to do your due diligence beforehand.
Hit up Damitre at Prime motoring in NJ.
Thanks for the responses… I agree with what you all said.
@justincredible thanks I’ll reach out to that shop in NJ for a quote.
