Engine out preventative maintenance
I may have a problem with a clogged cat. If so, I think I’ll embark on some engine out preventative maintenance mentioned in this post http://audirevolution.net/forum/index.php?topic=3145.msg91288#msg91288. Are these the correct part numbers for the items that are known to be at risk of wear or are extremely difficult to replace?
[tr][td]Starter w/exchange, $75 core charge[/td] [td]07C911023HX[/td] [td]jimellis[/td] [td]$282.00[/td][/tr]
[tr][td]Roller or Idler, Relay Roller[/td][td] 079903341F[/td] [td]jimellis[/td] [td]$34.00[/td][/tr]
[tr][td]Tensioner Roller for Alternator Belt w/ Hardware[/td] [td]079903133R[/td] [td]jimellis[/td] [td]$126.00[/td][/tr]
[tr][td]Belt, V-ribbed[/td] [td]07L903137E[/td] [td]jimellis[/td] [td]$40.00[/td][/tr]
[tr][td]Water pump + thermostat assy[/td] [td]079121012B[/td] [td]jimellis[/td] [td]$404.00[/td][/tr]
[tr][td] [/td][td]079121013N[/td] [td]FCPEuro[/td] [td]$383.00[/td][/tr]
[tr][td]Coolant pipe seal (x2)[/td][td]?? 07L103121M[/td] [td]jimellis[/td] [td]$7.00[/td][/tr]
Is there anything else I should put on my list?
plugs packs if you havent already. Check the fuel filter. If you have the intake off see about the intake spacers. I have heard they help not only keep the heat down adding performance but keeping the heat down gives a dencer charge of air and some guys are saying keeping more carbon away
These were also suggested by my mechanic
crankshaft oil seal, rear 079103051F
crankshaft oil seal, front 079103051G
oil separator 079103464D
valve stem seal, 6mm (x40) 100109001B
Hey… these are some of the parts that I ordered from JHM
2 x (OEM-07L103121M) - O-ring, Coolant Cross Over Pipes, Rear of Cylinder Head (OEM) for C6-S6 5.2L FSI V10
1 x (OEM-07L103650A) - Seal, Gasket for Spark Plug Bore, Cyl 1-5, Right (OEM) for C6-S6 5.2L FSI V10
1 x (OEM-07L103649A) - Seal, Gasket for Spark Plug Bore, Cyl 6-10, Left (OEM) for C6-S6 5.2L FSI V10
10 x (OEM-06E905115E) - Coil Pack, Ignition Coil (OEM) for B7-A4 3.2L, B8 S4-S5, B8 A4-A5 3.2L, C6 A6-S6, R8
10 x (NGK-PFR6W-TG) - Spark plug (NGK) Laser Platinum, Tri-electrode (OEM) for B8-S5 4.2L FSI V8
1 x (OEM-079903341F) - Roller or Idler, Relay Roller (OEM) for C6-S6 5.2L FSI V10
1 x (OEM-07L903133) - Tensioner Roller for Alternator Belt w/ Hardware (OEM) for C6-S6 5.2L FSI V10
1 x (CTI-5PK1135) - Belt for Alternator, Serpentine (Continental) for C6-S6 5.2L FSI V10
I should have posted the actual engine out thread here, but I forgot… so see this: http://audirevolution.net/forum/index.php?topic=3753.0
Thread bump… another thread about the service schedule for these cars mentions maintenance items that involve pulling the motor, so I think this thread would make a great resource for all the different items one should address while the motor is already out.
Agreed, maybe a yes or star around those items?
