Hey guys, I’m about to leave for Spain for 4 days so unfortunately I don’t have time to mess with it til tuesday, but a problem just came up in my 2007 S6…
I drove my car to work this morning, no problems at all. Went out for lunch, came back, still no problems at all. But when I left work in the evening, Immediately after hitting the gas pedal pulling out of the parking lot, the revs won’t go any higher than about 4k rpm, and the EPC and Engine lights come on. Oddly, the car runs fine below 4k rpm, If I don’t apply more than 50% throttle then it drives perfectly normally. If I mash the gas pedal, forget about it, car slows down instead of speeding up. Driving using a light foot, car was able to get up to 80mph no problem as long as I didn’t push the throttle too far.
When I got home, I pulled the terminal off the battery and let it sit for about 5 minutes, then connected it. I turned the ignition to “on” without starting the engine, mashed the throttle to the floor about 10 times, turned the ignition back to “off”, and then proceeded to start the engine. All looked good (and dash lights were gone) until I pushed the gas pedal past 50%, and suddenly it’s not letting me go over 4k again and the lights came back on.
So before I take it to the shop next week, I’m hoping to get a little input from you guys so I can walk in armed with at least a little information. Or maybe someone knows something I can check on my own first?
What I’ve read online seems to point to a problem with either the ECU, wiring, or a sensor.
Unfortunately I can’t get any VAG-COM readings til I got to the shop.
