ESP and EPC lights on and off, limps on and off......any ideas?
Hey all,
I have had about 3 weeks of happy motoring since the we replaced the IM with the JHM spacers - Ill give a review on that soon but alas the beast went into a limp mode yesterday, it self cleared while driving. I scanned her with the below results…
The next drive no lights, then the next day straight away. Its in the shop right now, problem occured on start on teh way to the shop - then turned off and never returned…
My gut says its ABS related, the ASR and ESP kicked out incl cruise etc, It went into a limp mode but no eng light has been present ever during this “evolution”
Any seen this type of intermittent fault?? Thoughts or ideas?? the private mech policy seems to be the best thing I have bought aside from the s6…
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Chappy
Monday,08,January,2018,19:04:21:62939
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 11 31 15 16 17 19 36 42 46 47 4F 52
53 55 56 57 61 62 69 6C 72 76 77
VIN: WAUZZZ4F97N092378 Mileage: 105760km/65716miles
03-ABS Brakes – Status: Malfunction 0010
07-Control Head – Status: OK 0000
0E-Media Player 1 – Status: Malfunction 0010
15-Airbags – Status: OK 0000
46-Central Conv. – Status: OK 0000
55-Xenon Range – Status: OK 0000
56-Radio – Status: OK 0000
57-TV Tuner – Status: OK 0000
61-Battery Regul. – Status: OK 0000
69-Trailer – Status: OK 0000
76-Park Assist – Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F1 910 552 C HW: 4F1 907 552
Component: 5.2L V10/4V FSI ª0060
Revision: 59H21— Serial number:
Coding: 01050000190F0160
Shop #: WSC 04940 001 00001
VCID: 24470A1BE72E243ED0B-8071
5 Faults Found:
001056 - Catalyst System; Bank 1
P0420 - 002 - Efficiency Below Threshold - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 104359 km
Time Indication: 0
Date: 2017.12.27
Time: 14:35:29
         Freeze Frame:
                RPM: 1336 /min
                Load: 23.1 %
                Speed: 49.0 km/h
                Temperature: 97.0°C
                Temperature: 40.0°C
                Absolute Pres.: 1010.0 mbar
                Voltage: 13.843 V
000805 - Knock Sensor 1 (G61)
P0325 - 008 - Malfunction - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 105168 km
Time Indication: 0
Date: 2018.01.04
Time: 14:49:10
         Freeze Frame:
                RPM: 2072 /min
                Load: 41.9 %
                Speed: 96.0 km/h
                Temperature: 95.0°C
                Temperature: 21.0°C
                Absolute Pres.: 940.0 mbar
                Voltage: 13.335 V
000104 - MAP/MAF <-> Throttle Position Correlation
P0068 - 002 -
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 105636 km
Time Indication: 0
Date: 2018.01.06
Time: 13:53:59
         Freeze Frame:
                RPM: 2178 /min
                Load: 36.8 %
                Speed: 100.0 km/h
                Temperature: 96.0°C
                Temperature: 32.0°C
                Absolute Pres.: 1000.0 mbar
                Voltage: 13.970 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 105754 km
Time Indication: 0
Date: 2018.01.08
Time: 17:34:56
         Freeze Frame:
                RPM: 2139 /min
                Load: 18.4 %
                Speed: 100.0 km/h
                Temperature: 96.0°C
                Temperature: 29.0°C
                Voltage: 13.843 V
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 105761 km
Time Indication: 0
Date: 2018.01.08
Time: 19:04:18
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 85.0°C
                Temperature: 66.0°C
                Voltage: 11.811 V
Readiness: 0000 0000
Part No SW: 4F2 910 156 M HW: 09E 927 156 C
Component: AG6 09E 5,2 FSI RdW 0030
Revision: --H01— Serial number: 0097544
Coding: 0000001
Shop #: WSC 36583 758 53164
VCID: 2F6DF537BEE897663D9-807A
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Coding: 0004536
Shop #: WSC 00010 824 177468
VCID: 3169F34FA8DC81962BD-8064
1 Fault Found:
01314 - Engine Control Module
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 3
Reset counter: 244
Mileage: 105754 km
Time Indication: 0
Date: 2018.01.08
Time: 17:34:56
         Freeze Frame:
                Hex Value: 0x6300
                Hex Value: 0x4006
                Hex Value: 0x0025
                Hex Value: 0x01AF
                Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 A HW: 4F0 905 852 C
Component: FBSAUDIC6 ELVSG H01 0030
Revision: 31050601 Serial number: 10601200610211
Coding: 0000019
Shop #: WSC 00010 824 94538
Subsystem 1 - Part No: 4F0 910 131 A
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 731 S HW: 4E0 035 729 A
Component: Interfacebox H43 3450
Revision: 00000000 Serial number: 351KV067531647
Coding: 0010002
Shop #: WSC 02335 785 00200
VCID: 326BFC43ADDABA8E527-8067
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000000598550
Subsystem 3 - Serial number: 0128.11.060000000100010621ÿ
Subsystem 4 - Serial number: 010621ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 A HW: 4F2 820 043 Q
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000052 Serial number: 00000030182666
Coding: 0525386
Shop #: WSC 02325 785 00200
VCID: 1C3732FBDF5E1CFE68B-8049
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0115121
VCID: 306FF64BA3D6889E243-8065
Subsystem 1 - Part No: 4F2 910 113 B Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H04 0190
Coding: 00064784
Shop #: WSC 00010
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 00010
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 A HW: 4E0 035 110 A
Component: MP3-Changer H44 0270
Revision: 00044000 Serial number: AUZ5ZBF3120715
Shop #: WSC 00000 000 00000
VCID: 162320D3217246AE5EF-8043
1 Fault Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 7
Fault Frequency: 1
Reset counter: 177
Mileage: 104070 km
Time Indication: 0
Date: 2017.12.14
Time: 15:15:57
         Freeze Frame:
                Text: 00000000
3 Faults Found:
012325 - Angle Sensor 1 for Throttle Drive 2 (G297)
P3025 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 105754 km
Time Indication: 0
Date: 2018.01.08
Time: 17:34:55
         Freeze Frame:
                RPM: 2163 /min
                Load: 16.9 %
                Speed: 100.0 km/h
                Temperature: 96.0°C
                Temperature: 29.0°C
                Voltage: 13.970 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 105754 km
Time Indication: 0
Date: 2018.01.08
Time: 17:34:56
         Freeze Frame:
                RPM: 2140 /min
                Load: 18.4 %
                Speed: 99.0 km/h
                Temperature: 96.0°C
                Temperature: 29.0°C
                Voltage: 13.970 V
001593 - Throttle Body Actuator Bank 2 (J544)
P0639 - 002 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 105759 km
Time Indication: 0
Date: 2018.01.08
Time: 17:39:44
         Freeze Frame:
                RPM: 1662 /min
                Load: 28.2 %
                Speed: 0.0 km/h
                Temperature: 99.0°C
                Temperature: 32.0°C
                Voltage: 11.430 V
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 4F AIRBAG AUDI8RH29 0280
Revision: 08H29000 Serial number: 0037LD0J1WR.
Coding: 0013382
VCID: 29591B2F800CF956E3D-807C
Subsystem 1 - Serial number: 6332CSME15484158/
Subsystem 2 - Serial number: 6342CSME15411A69%
Subsystem 3 - Serial number: 6352QSME1A427705D
Subsystem 4 - Serial number: 6362QSME18372365D
Subsystem 5 - Serial number: 63734SME18235051Q
Subsystem 6 - Serial number: 63834SME1A081F756
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90026063290323
Coding: 0112141
Shop #: WSC 02323 785 00200
VCID: E6C3D013D192962E8EF-80B3
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 931 G
Component: KOMBIINSTR. M73 H19 0120
Revision: 00000000 Serial number: 5H157YEC6
Coding: 2113848
Shop #: WSC 17586 067 57207
VCID: 23450907E2202306A91-8076
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B06B168236
Coding: F7D1DEF7301606
VCID: ECD7A23BCF7EAC7ED8B-80B9
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0091138
Shop #: WSC 06800 000 1048576
VCID: E1C9C30F38BCF1167BD-80B4
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00000000 Serial number: G6$
Coding: 0002810
Shop #: WSC 02327 785 00200
VCID: 2C57E23B8FFEEC7E18B-8079
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01025845140000
Coding: 0401905
VCID: 2E53E833B9E29E6E36F-807B
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H10 0240
Revision: PROD_01 Serial number: 00000000005969
Coding: 0000017
Shop #: WSC 02324 785 00200
VCID: 2541171FEC14DD36C75-8070
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000332913
Coding: 0011114
VCID: DEB3F8F309C2CEEE46F-808B
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00000000 Serial number: e#
Coding: 0002938
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04—
Coding: 0008021
VCID: 204F060BF336381EB43-8075
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000016
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 M HW: 4F0 035 541 H
Component: TUNER EU/US/RDW H42 0570
Revision: 00000000 Serial number: 394K+067710894
Coding: 0000001
VCID: 2A5BE423850AF24EEA7-807F
I don’t know how to read those ECU codes, but based on your symptoms it sounds like High Pressure Fuel Pumps need replacing. That factory ones only seem to last about 75-100k miles, and when one goes bad you get the exact symptoms you’re describing. They should be replaced in pairs, it’s a do-it-yourself type of job (they’re right on top of the engine), and they can be found for ~700 for the pair online. It’s the same part number for both passenger and driver side. Hopefully someone with more knowledge can chime in, but that’s what my guess is.
You do have a few ABS faults going on, by the looks of it, but I don’t think that would cause the intermittent “limp mode” problems. HPFP’s certainly would, though - the car would drive normal until you get on the throttle, then the engine would starve and it would struggle to get above about 4k rpm.
It’s a very common problem, I’d say most of us have had HPFP failures at some point or another.
The good news is it looks like it might not be ABS related
Here is the code that will put you into limp mode right when it pops up
Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 105754 km
Time Indication: 0
Date: 2018.01.08
Time: 17:34:55
         Freeze Frame:
                RPM: 2163 /min
                Load: 16.9 %
                Speed: 100.0 km/h
                Temperature: 96.0°C
                Temperature: 29.0°C
                Voltage: 13.970 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 105754 km
Time Indication: 0
Date: 2018.01.08
Time: 17:34:56
         Freeze Frame:
                RPM: 2140 /min
                Load: 18.4 %
                Speed: 99.0 km/h
                Temperature: 96.0°C
                Temperature: 29.0°C
                Voltage: 13.970 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 105759 km
Time Indication: 0
Date: 2018.01.08
Time: 17:39:44
         Freeze Frame:
                RPM: 1662 /min
                Load: 28.2 %
                Speed: 0.0 km/h
                Temperature: 99.0°C
                Temperature: 32.0°C
                Voltage: 11.430 V
While you did have an ABS code you will always get an ABS error if you get a throttle drive code. Chances are the throttle bodys were just not master aligned after putting on the new intake.
You can realign that in vag com or you can just pull the battery terminals zero out the system by holding the postive and negitive terminals together for 45 seconds. This pulls any stored energy out of the system. From there connect the terminals back on and leave the key forward for 2 min not starting the car. then open the door turn key off and turn key back on for 2 min to have the throttle bodies relearn.
this isnt always the master fix but most of the time if you dont have any mechanical issues this will help get you where you need to be.
also just to check on the ABS try clearing the module and see if any codes pop up directly after start and the first pressing of the brake pedal .
Good post.
I didnt see any direct codes for HPFP but WE KNOW that between the HPFP and the injectors them selves that they NEED to get instpected or replaced before 100k so good point to bring up.
Neil if you can try to clear the ABS codes and see if they pop right back up
Coding: 0004536
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 244
Mileage: 105754 km
Time Indication: 0
Date: 2018.01.08
Time: 17:34:56
Obviously you would do this by going into the ABS system in vag com
Interesting - the car itself was driving very well, we did about 1000miles plus with no dramas until the lights flashed up which happened cruising at about 30MPH. When the lights are on shes in a limp style mode, soon as they go out full power returns. Ill keep an eye on those, I have pretty much zero history with this car so its prob a good idea to do these HPFPs at some point soon!
Hey Justin - see this is why these forums can be super helpful! I will pass this intel onto the shop (I dropped it of yesterday - incase it was going to be a insurance claim…ABS pumps are pricey and i got scared hahahahahah)
Thanks again I will keep you all posted.
Chap
When mine had these symptoms - it was the wiring connectors for the throttle bodies. Fought this for months before I finally replaced them and it has been fault free since!
I believe that a weak battery causes many seemingly unrelated codes to be thrown.
Id recommend clear the codes, charge the battery and see what comes back.
My .02
Good luck & report back.
And the winner is!
Shop confirmed it was the throttle body on bank two - they cleaned the connectors and tested with no further faults, did you replace the connector or whole throttle bodies??
Cheers
Good thread. I had a similar issue tonight on the way home. Will post a separate thread. Looking forward to hearing everyone’s thoughts.
Yeah Sweet - I have not had an issue thus far, the bonnet “loose” sensor is flickering at the moment, but I can manage that for now!
WOW this is actually becoming something we are seeing more and more. Any chance they can offer more information on what needed to get cleaned. This sounds odd as obviously the conenctors are connected so I don’t know how they would need to get cleaned.
Did you do any work on the car lately that required you to remove the throttle body wires
Hey Justin,
So the guys cleaned everything, the throttle body connectors and the and the internal bodies themselves. They had replaced the manifold about 500 miles earlier, pretty sure that would require a removal and fiddle!
It would indeed requite a removal of the throttle bodys or at the very least the throttle drive electronic connection.
Thanks again for that update. I think this is something sneaky that most don’t know about and look for. A great thing to inspect when your doing a carbon clean or installing the intake spacers or any maintenance that requires messing with the intake including the oil separator. I think its just a good thing to check.
Some have said the wire harness is weak and falls apart. I know for 100% sure we see this on the B6 S4. The wire coating gets heat stressed and cracks exposing the bare wire. Sooner or later they ground out and blow fuses. Its not fun but now that everyone kinda knows what to look for its been a major help.
